3D-Max AppLink
  • Please log in to reply
129 replies to this topic
#41 Alco3d
Alco3d
    Neophyte
  • Pip
  • 36 posts
Posted 03 April 2015 - 02:04 AM
Few times i try to install Applink for my 3dsmax 2014. I try different version Applink but it doesn't work. When i click on Manual update occur nothing. Can it be, because i have cyrillic letters in the path to Exchange folder? I know some programm (Alias studio, Keyshot) doesn't work for this reason.
Thanks!
#42 nalan520
nalan520
    Newbie
  • 6 posts
Posted 12 April 2015 - 10:59 AM
Thanks!
Yes, it doesn't work for 3dsmax2014.
Keep trying··· ···
#43 carlosan
carlosan
    Master
  • Custodian
  • PipPipPipPipPipPip
  • 5,411 posts
  • Gender:Male
  • Interests:Character Design, Drawing, Sculpture, Modeling, Texture Paint.
Posted 15 May 2015 - 02:24 AM
With the latest BETA19 build my 3ds max AppLink stoped to remember Path and Folder paths between 3ds max sessions. Every time I want to use AppLink I have to setup paths again. Is there a way to fix it on my side?
Update. It looks like AppLink script needs to be updated. There are some text strings which point to 3D-CoatV4 instead of 3D-CoatV45.
if (findString pathtoIO "3D-CoatV4\\Exchange\\")==undefined then (
    a=pathConfig.convertPathToAbsolute "meshes"
    t=(findString a "Documents")+9
    tt=(substring a 1 t)+"3D-CoatV4\\Exchange\\"
    if (doesFileExist tt) then pathtoIO=tt
My Blogfolio
Google+ link
3DC Google+ Community
#44 AbnRanger
AbnRanger
    Master
  • 6,415 posts
  • Gender:Male
Posted 15 May 2015 - 05:54 PM
Just successfully installed it in 3ds Max 2016, so it should be up to date, still
#45 AbnRanger
AbnRanger
    Master
  • 6,415 posts
  • Gender:Male
Posted 14 June 2015 - 03:49 PM
Seems 3D Coat's renaming of the MyDocs/ 3D-CoatV4 directory has made the Applink unusable, now. Probably the case for all the applinks, not just Max. Please fix. I tried to go into the 3ds Max applink.ms file and change the directory name, manually, but for some reason that didn't work.
#46 zFarm
zFarm
    Neophyte
  • Pip
  • 22 posts
Posted 05 August 2015 - 05:33 AM
Hi. I'm new the 3dc but wanted to use my PBR material/tex in max. It there a workflow for that? This is what I have in 3dc and max now. trying mental ray and vray.
#47 AbnRanger
AbnRanger
    Master
  • 6,415 posts
  • Gender:Male
Posted 21 August 2015 - 11:17 AM
The script installs in 3ds Max 2016 ok, but when you begin to try and USE it, the applink is borked. Nothing I tried worked. I even tried to change the filepath in the .ms file, to 3D-CoatV45, but no joy.
#48 PolyHertz
PolyHertz
    Novice
  • PipPip
  • 468 posts
  • Gender:Male
Posted 21 October 2015 - 02:37 AM
This script is weird. I couldn't get it to work until I went into the macro_3DS_AppLink.mcr file and properly tabbed the lines (I find it hard to read scripts without formatting)...
Either way, works fine now in both max 2012 and max 2016, using 3DC 4.1 and 4.5
Creator of the 3DSMax <->3DCoat Applink.
#49 AbnRanger
AbnRanger
    Master
  • 6,415 posts
  • Gender:Male
Posted 21 October 2015 - 05:03 AM
I can install it, but I cannot get assets back and forth between the two apps, because the folder name has changed to 3D Coat V45, and it hasn't been updated. I asked Andrew about it, and he said he would inform the guy working on the script. Months later....still no joy. Have you tried moving assets back and forth between them?
#50 PolyHertz
PolyHertz
    Novice
  • PipPip
  • 468 posts
  • Gender:Male
Posted 21 October 2015 - 09:22 AM
Yep, back and forth works, but there's a lot of extra BS past what I did with the install.
It might just be something with my computers permissions (I'm admin, so...) but the way pathtoIO.ini file is handled is seriously busted. As a result, before every max/applink session it needs to be deleted (C:\Program Files\Autodesk\3ds Max 2016\MacroScripts\macro_3DS_AppLink). Unfortunately it gets locked the moment its used once, so if you ever close the applink window you'll need to restart max (and delete the ini) before it'll work properly again. Also due to the ini issues, you will need to re-input the exchange path and output folder at the top of the applik window once for ever session.
#51 PolyHertz
PolyHertz
    Novice
  • PipPip
  • 468 posts
  • Gender:Male
Posted 21 October 2015 - 02:09 PM
If that doesn't work for you, I got fed up really quickly with the ini file issues and created my own (simplified) 3DSMax<->3DCoat applink.
You can grab it here: https://dl.dropboxus..._3DCappLink.mcr
You'll need to enter your paths in the top of the file via a text editor since I haven't bothered adding inputs to the UI. Though I can add more functions from the regular applink if there's any interest
Edited by PolyHertz, 21 October 2015 - 02:13 PM.
#52 PolyHertz
PolyHertz
    Novice
  • PipPip
  • 468 posts
  • Gender:Male
Posted 21 October 2015 - 09:42 PM
Small update: It now automatically detects the versions of 3DC installed and selects the newest one, with the option to select older versions from a drop down at the bottom. A bit faster then inputting the paths like in the official applink.
Also, the icons work so long as you load them into the IconsDark folder (The regular icons folder, which offical applink installs them to, is not the default in current max versions).
Edited by PolyHertz, 21 October 2015 - 10:00 PM.
#53 AbnRanger
AbnRanger
    Master
  • 6,415 posts
  • Gender:Male
Posted 22 October 2015 - 01:33 PM
So, do I copy paste the text into the old applink? Cause when I click on the link the text opens in a browser window, rather than downloading as a file
#54 PolyHertz
PolyHertz
    Novice
  • PipPip
  • 468 posts
  • Gender:Male
Posted 22 October 2015 - 02:53 PM
Right click and 'save as' to somewhere on your computer, then within max go to scripting > run script , and open it from there.
Afterwords you can find it under customize > customize user interface > Keyboard/Toolbars tab > category > GregsScripts. Then either bind it to a hotkey or drag-drop it somewhere on the Max toolbar.
#55 Александр
Александр
    Newbie
  • New Member
  • 1 posts
Posted 22 October 2015 - 07:11 PM
2015 и 2016 3д Макс нет
ScriptAttack . :angry:
#56 PolyHertz
PolyHertz
    Novice
  • PipPip
  • 468 posts
  • Gender:Male
Posted 22 October 2015 - 11:46 PM
Updated my applink again, now with the ability for it to automatically create/apply PBR materials when importing back into Max (Max2016 only), or assign flat colors+opacity for low spec work.
  • carlosan likes this
#57 AbnRanger
AbnRanger
    Master
  • 6,415 posts
  • Gender:Male
Posted 23 October 2015 - 03:08 AM
Thanks for taking the time on this. I was sweating this applink after months of silence.
#58 AbnRanger
AbnRanger
    Master
  • 6,415 posts
  • Gender:Male
Posted 23 October 2015 - 03:14 AM
I think he stopped working on it a few years ago. Not sure why.
#59 PolyHertz
PolyHertz
    Novice
  • PipPip
  • 468 posts
  • Gender:Male
Posted 28 October 2015 - 07:57 AM
New version!
-Option to auto-launch 3DCoat app if an instance is not already running.
-Option to auto-switch to 3D-Coat app on mesh export. (didn't feel like a proper applink without it.)
-Added ability to export Curve Profile and Voxel Comine objects (added in v1.2 and v1.3 applink specification)
-Ability to dock window to left or right of Max viewport.
-Ability to Auto-delete by name, by user properties tag (system used by official applink), or by both.
-PBR option now only shown if running Max2016 or newer.
-Support for saving settings (just the checkboxes for now).
Same link as always. Have fun :)
No problem, hopefully you and others can find some use for it. Let me know if there's any changes you'd like to see made (haven't actually gotten any feedback on it yet...).
I also noticed andrew linked to it on the first post. Does that make it the 'official' applink now? :p
#60 AbnRanger
AbnRanger
    Master
  • 6,415 posts
  • Gender:Male
Posted 28 October 2015 - 11:41 AM
New version!
I guess it does. :D That's where most users would look for the current one.
