Advanced Member popwfx Posted January 1, 2013 Advanced Member Report Share Posted January 1, 2013 I personally would appreciate if text in the Layers, Sub-Objects & Materials/surfaces lists could in fact NOT be centered. If you left-justify them they are much easier to read (at least with a left-to-right language - I don't know if 3DC is availble in right-to-left languages but if so then it should probably be right justified for those users) Centering them makes scanning a long list hard to find things. Often times I will use naming conventions for my layers or sub-objects and something might be called: building.front.spec building.front.depth building.entrance.depth See how this list below lines things up better and is easier to visually scan? building.front.spec building.front.depth building.entrance.depth I don't want to sound like I'm splitting hairs or nitpicking an otherwise excellent application. It's just minor stuff like this that is easy to do adds up and helps workflow. Also, hopefully doing this might lead to the Layers list eventually having thumbnails like in Photoshop or linked masks in-line like in Photoshop etc. Or dare I say a filter/search box at the top of the Layers lists for long lists - though this may not be as needed if folder groups (as in my other thread) is added... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 1, 2013 Report Share Posted January 1, 2013 Hi There is a mantis request open http://3d-coat.com/mantis/view.php?id=744 feel free to open a mantis account and add your comment there, ty ! note: mantis is the 3DC bug tracker Quote Link to comment Share on other sites More sharing options...
Advanced Member popwfx Posted January 1, 2013 Author Advanced Member Report Share Posted January 1, 2013 just added my support for this in Mantis Quote Link to comment Share on other sites More sharing options...
