Imports don't appear in the Voxel Room
SPACEY
I just started using the trial of 3DCoat today and when I import models OBJ/LW they disappear when I switch to the Voxel tab. Also some of the Voxel sculpt tools(Cutoff) seem to be missing from the toolbar. Lastly, I saved a workspace, but it does not appear when I go to Restore. Are these trial version issues?
trial begin first time your open the version
and can install 2 version
like example
i can test v3 one month and when trial finish... install v4 and try it another month
Are you doing:
Import
import mesh for voxelizing
Voxel Room is an old name ready to be changed -old v3 legacy-
Is Sculpt Room where you can find 2 Sculpt modes
Voxels: good mode to make the overall shape. We begin here.
Surfaces: better mode to add details before to do a retopo stage
If you switch to surface mode (pressing the V -voxel mode- in the layer name switch the object to S -surface mode-)
And now You yes can paint the object at paint room and back and forth between paint and voxel.
