Contributor ajz3d Posted February 12, 2013 Contributor Report Share Posted February 12, 2013 Is it possible to change the freeze pattern from checkered texture to something else, like to a custom texture, shading (grayscale or RGB)? After working for half an hour zoomed in on the pattern I feel like my eyes are about to explode. Also with the checker I can't really tell whether I have frozen everything to 100% or some semi-frozen areas still remain. Thanks. EDIT: Oh, I think I've found that checker texture file. It's in \textures\checker1.tga. I will try to change it to something else and see what happens. Nope, that's not it. The checker remains. Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted February 12, 2013 Advanced Member Report Share Posted February 12, 2013 Is it possible to change the freeze pattern from checkered texture to something else, like to a custom texture, shading (grayscale or RGB)? After working for half an hour zoomed in on the pattern I feel like my eyes are about to explode. Also with the checker I can't really tell whether I have frozen everything to 100% or some semi-frozen areas still remain. Thanks. EDIT: Oh, I think I've found that checker texture file. It's in \textures\checker1.tga. I will try to change it to something else and see what happens. Nope, that's not it. The checker remains. Under the Freeze pulldown is an option "Toggle freeze view" (Alt+F) this will toggle through different display modes for the frozen area. The black works well. Different shades of gray for different Freeze degree (sold black is 100%) Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted February 12, 2013 Author Contributor Report Share Posted February 12, 2013 It seems the darkest place is always under the lantern. Many thanks, Bisenberger. Andrew thought about everything. Quote Link to comment Share on other sites More sharing options...
Advanced Member bisenberger Posted February 13, 2013 Advanced Member Report Share Posted February 13, 2013 It seems the darkest place is always under the lantern. Many thanks, Bisenberger. Andrew thought about everything. Your welcome. I think you are right on both accounts. Quote Link to comment Share on other sites More sharing options...
