New Member baland Posted September 8, 2008 New Member Report Share Posted September 8, 2008 Hi everybody. just trying to get my head around 3DC - what I saw until now it pretty impressive. I have got a figure to texture with 3 map areas in it - DazV4, of course. Is it possible to get the entire body as obj into 3DC, and use the original, 3-parted UVs for it? The required result is just the maps, don't need the (already presculpted) geometry data. Tried several ways, but didn't get a result. Thanks in advance. Btw - NICE application! Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 8, 2008 Report Share Posted September 8, 2008 Hi everybody.just trying to get my head around 3DC - what I saw until now it pretty impressive. I have got a figure to texture with 3 map areas in it - DazV4, of course. Is it possible to get the entire body as obj into 3DC, and use the original, 3-parted UVs for it? The required result is just the maps, don't need the (already presculpted) geometry data. Tried several ways, but didn't get a result. Thanks in advance. Btw - NICE application! 3D-Coat supports multiple uv-sets. But please check if they are not self-overlapping. Are you trying to import OBJ? Quote Link to comment Share on other sites More sharing options...
New Member baland Posted September 9, 2008 Author New Member Report Share Posted September 9, 2008 3D-Coat supports multiple uv-sets. But please check if they are not self-overlapping. Are you trying to import OBJ? Hi Andrew, thanx for the reply. I tried to work with an OBJ consisting from about 60 groups (some 66k vertices) and there are 3 non-overlapping maps applied. It#s the "millenium" mesh from DAZ 3D. I simply seem to be unable to get my head around how to import the obj and the maps. Didn't find anything about that workflow in the manual. Would love to work with , cause it's so much faster than ZBr on my XP64 machine, and the GUI is great, too. Thanx! Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 9, 2008 Report Share Posted September 9, 2008 Hi Andrew, thanx for the reply.I tried to work with an OBJ consisting from about 60 groups (some 66k vertices) and there are 3 non-overlapping maps applied. It#s the "millenium" mesh from DAZ 3D. I simply seem to be unable to get my head around how to import the obj and the maps. Didn't find anything about that workflow in the manual. Would love to work with , cause it's so much faster than ZBr on my XP64 machine, and the GUI is great, too. Thanx! Is it possible to test that mesh? If possible, please send it to me (support@3d-coat.com). I will not distribute or use mesh besided testing. Quote Link to comment Share on other sites More sharing options...
New Member baland Posted September 10, 2008 Author New Member Report Share Posted September 10, 2008 OK - I've found a workaround. The Problem with Poser figures seam to be, that geometry and material grouping differs. I'll get some more practice and will take some screenshots while working on a commercial project. Will set up a tutorial for the combination of Poser & 3D-Coat during the next weekend. Quote Link to comment Share on other sites More sharing options...
Advanced Member Oliver Thornton Posted September 11, 2008 Advanced Member Report Share Posted September 11, 2008 Do you just have Poser and 3DC? If you have Lightwave you can fix this fairly easily and output the model as a lwo to preserve the 3 UV sets. If not, auto uv-mapping might work but you'll have to re-export and re-rig the model in Poser because the UVs won't match. -Oliver Quote Link to comment Share on other sites More sharing options...
