Member Daniel Tynan Posted July 13, 2015 Member Share Posted July 13, 2015 The plane carving tool for in Voxel sculpting could be VERY useful. .however it is tricky to use because you have to select 3 or 4 points on the surface and cross your fingers and hope the resulting plane will be where you want it and and the right angle. It would be MUCH easier to just have an actual preview. . semi transparent plane that you can rotate and move in any direction and get the perfect placement. and scale. . lock it and start carving away those planes. Anyone else agree? Quote Link to comment Share on other sites More sharing options...
Taros Posted July 13, 2015 Share Posted July 13, 2015 Definitely. And a manager for saving/loading positions. Like saving splines. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted July 13, 2015 Reputable Contributor Share Posted July 13, 2015 (edited) We used to have a grid that showed your cutting plane position when using the points... Also the points appeared on the surface so you could move them and then the grid would reposition in realtime. This appears broken now in the lastest beta... No grid and no points on the surface. I posted this information in the beta thread as well... Edited July 13, 2015 by digman Quote Link to comment Share on other sites More sharing options...
