New Member Bryan Posted July 19, 2015 New Member Report Share Posted July 19, 2015 I have a model I've painted, and I can't seem to export the texture; choosing 'Textures' -> 'Export' -> 'All Layers Color' produces transparent (empty) layers in the Photoshop file. It's also 256x256 which leads to my second question: choosing 'Edit' -> 'Mesh & Texture Resolution' doesn't do anything-- is this where you'd set the size of the exported texture images? EDIT: one more question-- when I export 'object and textures', I'm only getting the files for the object (obj file) and the material (mtl file) but not the actual image file that goes along with the material. Thanks! Bryan Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 22, 2015 Report Share Posted July 22, 2015 Hi Only this model or any model give same result ? Are you using the last verison ? Quote Link to comment Share on other sites More sharing options...
