Advanced Member Ballistic_Tension Posted September 9, 2015 Advanced Member Report Share Posted September 9, 2015 in PPP imported a model from blender . clicked on smart materials it then does the cavity mask (auto) layer and I said yes to the ao layer but decided to delete the ao layer which it did then I tried to delete the cavity mask layer and 3dc crashed right away. I then reopened and a lot of my or all setups window popups my whole layout was gone . I also had to set the Normal map Software Preset from unknown to blender meaning it crashed hard man... Its some bad mojo I am not going to try it again . thanks for your time on this. win8.1 (DX) 64 CUDA AND 4.5.03 Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted September 9, 2015 Solution Report Share Posted September 9, 2015 this issue was solved on version 4.5.16 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted September 10, 2015 Author Advanced Member Report Share Posted September 10, 2015 Thanks Carlosan I have in documents ( 3 ) 3dcoat versions 1) 3dcoat V3 This only has one folder >Exchange which has 2 text docs 2nd) 3D-Coat V4 3rd) 3D-Coat V45 should I rename v4 or v45 as OLD then install 4.5.16 version or can I just install 4.5.16 in there also? I mostly just wait for the stable factory builds but would like to try this build as it is marked stable . thanks same with windows 10 ill wait a bit till I load that up. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 10, 2015 Report Share Posted September 10, 2015 Quote Link to comment Share on other sites More sharing options...
