New Member kieutrinh15 Posted October 22, 2015 New Member Report Share Posted October 22, 2015 Hi, I'm Trinh and I'm a newbie here. I'm having this problem: I cannot select the whole face of object, to move it in pose tool. There's only one face selected, like below: I want to select all the faces of selected area. If you know the answer, please help. I'm really appreciated. Thank you so much! Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution digman Posted October 22, 2015 Reputable Contributor Solution Report Share Posted October 22, 2015 Under the E-Panel... (Brush and splines Panel) deselect "ignore back faces" 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 22, 2015 Reputable Contributor Report Share Posted October 22, 2015 Also, don't use any of the selection marquess in the E-Panel when working with the LINE selection. Use one of the brushes. Andrew should grey out those selection marquees by default, when that mode is chosen 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 22, 2015 Reputable Contributor Report Share Posted October 22, 2015 ...same thing goes for the ring or sphere modes. Only use the marquees with the Select by PEN or OBJECT modes 1 Quote Link to comment Share on other sites More sharing options...
Contributor TimmyZDesign Posted October 23, 2015 Contributor Report Share Posted October 23, 2015 Also maybe adjust your falloff or border width. 1 Quote Link to comment Share on other sites More sharing options...
