Member aaronmcavinue Posted December 14, 2015 Member Report Share Posted December 14, 2015 See the attached image -- very helpful. As you can see, the mesh is unwrapped neatly, and there isn't much information on the layers, but they are still acquiring some kind of grungy artifacts (which don't appear to be from a low-res texture or something). I'm not using any alphas, just the standard brush, and no smart materials. Any idea what is going on & how to fix it? Thanks in advance! Aaron 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted December 14, 2015 Reputable Contributor Report Share Posted December 14, 2015 (edited) Have you Deselected "Show Voxels in Paint Room" under the Paint Room / View Menu... This is always on by default each time you load 3DC. Also if you this is a rebake, read my current post to your other thread... Also you do not have all your available tabs... You are missing some like your Paint Objects tab. etc... Go to the Windows menu and select "Reset this page to default" Edited December 14, 2015 by digman 1 Quote Link to comment Share on other sites More sharing options...
Member aaronmcavinue Posted December 14, 2015 Author Member Report Share Posted December 14, 2015 That wasn't deselected but the problem somehow got fixed. I turned the model on/off in the voxtree and this seemed to fix the problem somehow... :p 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted December 14, 2015 Reputable Contributor Report Share Posted December 14, 2015 If you turn the model off in the voxtree it does the same thing as now it is hidden... 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted December 15, 2015 Advanced Member Report Share Posted December 15, 2015 I just had this problem but in the Render Room .I had show Voxels off in the paint room as to show the (low poly) mesh and painted on it with normal map then went to render room and saw the voxel overlay lol. funny thing was I went to the sculpt room moved the (high poly )Voxel over and rendered both . 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution digman Posted December 15, 2015 Reputable Contributor Solution Report Share Posted December 15, 2015 (edited) I just had this problem but in the Render Room .I had show Voxels off in the paint room as to show the (low poly) mesh and painted on it with normal map then went to render room and saw the voxel overlay lol. funny thing was I went to the sculpt room moved the (high poly )Voxel over and rendered both . Yep, that is how it works. Voxels show up in the paint room for Vertex Painting (polypainting). They are switched to polygons / surface mode . You would still desire the surface mode object to show up for rendering. Only hiding the voxel / surface mesh when painting a baked object in the paint room. You stiill have to hide the voxel / surface mesh then in the sculpt room when rendering your baked object. Depends upon what workflow you are using whether to use the View Menu way or just hide the voxel object using the vox tree tab. I tend to use the view menu as a few times when I had a baked object, I hid the voxel model / models using the voxtree tab, then being in a hurry re-baked without unhiding them... no high sculpt to bake the details from... Ouch. LOL... Edited December 15, 2015 by digman 1 Quote Link to comment Share on other sites More sharing options...
