Member ahmad Posted March 4, 2016 Member Report Share Posted March 4, 2016 Hi I always wanted to have a paint brush like the polygon brush in paint room, but as soon as I used it i started to feel the need for a similar brush which paint an object within the object, for example: I want to paint an eye that is attached to the face in one single object ... I could use the paint polygon brush for the visible faces but I cant paint the back side of the eye, so one brush could paint the entire eye will be great Quote Link to comment Share on other sites More sharing options...
Advanced Member gbball Posted March 7, 2016 Advanced Member Report Share Posted March 7, 2016 That's a good idea...It would be a good e panel stroke type...or a modified function of the paint polygon tool. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution AbnRanger Posted March 7, 2016 Reputable Contributor Solution Report Share Posted March 7, 2016 Hi I always wanted to have a paint brush like the polygon brush in paint room, but as soon as I used it i started to feel the need for a similar brush which paint an object within the object, for example: I want to paint an eye that is attached to the face in one single object ... I could use the paint polygon brush for the visible faces but I cant paint the back side of the eye, so one brush could paint the entire eye will be great The fill tool does that very thing. It paints contiguous objects (such as an eye) with a single click. It even does it with UV shells/Islands in the 2D Editor. Quote Link to comment Share on other sites More sharing options...
