Advanced Member Gary Dave Posted March 15, 2016 Advanced Member Report Share Posted March 15, 2016 V 4.5.19 Obviously I'm not suggesting that my mesh is breaking down the longer I stay in 3dc, BUT... something very funky is going on. For context, these particular mesh pieces haven't been worked on. I created them via vox-layer and they are separate from the base piece that I've been working on tonight. I'm 90% sure when I created them they were fine, and I loaded up my earliest save to see if this "corruption" was still present, it was... but only very little. So it definitely got worse, somewhere, somehow. Image of it currently:http://i.imgur.com/TywJuLZ.png And here's what it looked like from an earlier save: (You can see it's mostly fine, the but the left most panel is showing some oddness that was NOT present on creation. http://i.imgur.com/D9uZ3lU.png The only work I've been doing tonight is hiding and "object-ify hidden" on a completely different mesh to the one that I'm showing here. Annnd lastly, I think my other mesh pieces might be on their way out too, I can't tell... it could be a shader related thing (PicMat_RedWax) as I know that has some funky stuff when you zoom in, but I'm not zoomed in, those weird "mesh broken" artifacts actually appear to exist everywhere in my scene when viewing my model as a whole. http://i.imgur.com/JBduB7A.png Anyone know what's going on? I've tried resampling, using mesh doctor, switching to voxel/surface and back. Can't seem to fix it, and as for the original vox-layer mesh pieces above, those can't be fixed, but I'd love to know why they're going weird on me. It seems to get progressively worse the more I use VoxHide and Object-Ify Hidden, despite the fact that I'm not using it on any of the pieces shown above. Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 16, 2016 Author Advanced Member Report Share Posted March 16, 2016 Bumpy bump. I'm beginning to suspect that the problem is related to remnants of the vox-layer's freeze/selection functionality. Despite the fact that I used vox-layer to create these pieces, and have not used vox-layer ON these pieces, I noticed little patches of dark grey on the mesh from time to time, that went away when I pressed Ctrl + D while on that layer. Again, I should note... I was not using vox-layer on these pieces, there's no reason why any portion of it should be "frozen", let alone random little patches. I have also not used "through all volumes" while using vox-layer. So, the current theory, is that remnants of the freeze/selection from vox-layer are appearing where they shouldn't, and that when a mesh/layer has little patches of frozen geometry, it starts to go "wonky" when using the VoxHide + Object-ify Hidden, despite not using ANY of these tools on the layer that's getting "corrupted over time" Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 16, 2016 Report Share Posted March 16, 2016 hmmmm... let me test Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 17, 2016 Author Advanced Member Report Share Posted March 17, 2016 I can't seem to re-create it, but I think I've stumbled onto a different issue. "Object-ify Hidden" seems to remember previously un-hidden geometry, and will still turn them into objects when using Hide + Objec-ify Hidden again. Maybe a quick video will better explain this. It could be normal behaviour, but it shouldn't be! Apologies, it didn't record my cursor which makes this a bit weird. But here's what's happening:Hide and "object-ify hidden" 2 blocks from the main cube. - creates new layer for the new objects Hide and "object-ify hidden" a few blocks from the bottom of the main cube - creates new layer for the new objects and also the blocks from before. Then, WITHOUT using VoxHide again, go to "Object-ify Hidden" and it still pumps all of the previous 2 selections into a new layer. So it seems to not be forgetting that it's already unhidden some hidden selections. Perhaps this is related to my earlier issue in some way, and that maybe I've accidentally been merging meshes ontop of each other, causing all sorts of little chaos? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 17, 2016 Report Share Posted March 17, 2016 Will you please try to select another tool and perform object-ify hidden again the tool keep the last operation in cache, select another tool clear the cache Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 17, 2016 Author Advanced Member Report Share Posted March 17, 2016 Ah right, interesting. I can't test it now, will have to wait til after work, but when you perform an Object-ify Hidden, it automatically switches to the Transform tool, so this should be clearing the cache in theory? Unless switching to the transform tool doesn't count? Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted March 18, 2016 Author Advanced Member Report Share Posted March 18, 2016 Yeah, this seems pretty broken. In the video below you see me switching through various tools before going back to using VoxHide again, but the second use of Object-ify Hidden always includes the first selection also. Quote Link to comment Share on other sites More sharing options...
