Advanced Member geo_n Posted October 15, 2016 Advanced Member Report Share Posted October 15, 2016 Does 3dcoat support vrml, 3dm with vertex color embedded? Vrml is standard colored printing format. The colors can be embedded. 3dm is new format for colored printing which is used also by win 10 3dbuilder. Probably will be supported by mspaint3d. I tried importing vrml and 3dcoat just crashed. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 15, 2016 Report Share Posted October 15, 2016 .wrl Hi ! Can you export wrl o try changing name extension ? Quote Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted October 15, 2016 Author Advanced Member Report Share Posted October 15, 2016 Sorry its wrl extension but its commonly known as vrml right? Here's a sample file with embedded vertex map. The 3dm file can be saved from windows 10 3dbuilder. I don't know if that's a closed format or can we import/export that in the future. PolySphere.zip Quote Link to comment Share on other sites More sharing options...
Advanced Member sculptactive Posted October 15, 2016 Advanced Member Report Share Posted October 15, 2016 (edited) VRLM is a bit of a minefield . 3DC exports VRLM perfectly, however when I try and import back the file there is no colour data. This also applies to other software like Modo. However I know the VRML export is good, because if I open the exported file in Meshlab or 3DBuilder all the colour data is good. I would highly recommend downloading Meshlab to test your files. I tried to test your file but I got the "out of memory" too which is weird as it is only 4mb. There must be another issue with your file, (maybe send it to support) as all my VRML files which are much larger import perfectly, all be it without any colour data. 3DC also exports DAE which some printers except for colour printing... Edited October 15, 2016 by sculptactive Quote Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted October 15, 2016 Author Advanced Member Report Share Posted October 15, 2016 I was able to import that sphere in both 3dbuilder and zprint 7.12 successfully with color. I did get the same out of memory error you got in 3dc. So its a 3dc issue. The file is from zbrushcore. It supports colored output by using vrml and embedded the polypaint into it. i wanted to try to import to 3dc and continue painting it but couldn't import it successfully. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 15, 2016 Report Share Posted October 15, 2016 3DC is very sensitive importing ngons. try to convert any ngon to tris or quads before import it. Quote Link to comment Share on other sites More sharing options...
