Member Gwyvern Posted November 16, 2016 Member Report Share Posted November 16, 2016 Heya all, this one's pretty simple. I'm trying to add detail to the normal, I already know how to turn off color and roughness for the brush, but the actual functionality of the normal editing has me a bit stumped. To save a lot of words, I drew a sloppy diagram. What happens between stroke 1 and 2 is the left example, what I want to happen is the right example. Also, I've been learning about smart materials, and have been trying to figure out how to scale the tiled effects of certain smart materials. I found someone asking the same question, and the only answer was to use the "magnifier" on "the top bar" Both of which are things I can't seem to locate. This community has been very helpful so far, thank you all for your patience. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 16, 2016 Report Share Posted November 16, 2016 Hi ! Are you asking for this or this ? Quote Link to comment Share on other sites More sharing options...
Member Gwyvern Posted November 16, 2016 Author Member Report Share Posted November 16, 2016 Wow, yes, thank you very much! You wouldn't happen to know about my second question would you? Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted November 16, 2016 Advanced Member Report Share Posted November 16, 2016 when you select a Smart Material a Long Window will show up its called Preview Options it is here you will find the magnifier it will be on the right side. You can also move the Smart Material Preview window over your object to see how it will look . Quote Link to comment Share on other sites More sharing options...
