Missing maps?
MartianGirl
Hi again everyone,
So sorry to keep posting my newbie questions. I have been scouring the  forums for answers,but can't seem to find the answer I need.
I have been testing the baking, even though I have followed the amazing advice from Abranger and lots of videos on you tube, I can't seem to make it work. I am clearly missing a step somewhere.
I have my High Poly model and my Low Poly retopo all named and on layers.
 The Uv seams all done, the uvs packed the way I need them.
I have to bake  parts separately.
 After  baking a part,  I go to the paint room and there is nothing in the texture editor.
I turn off the vox tree and there is no lowpoly model with any baked goodies on it.
Am, I missing a simple step?
All help, very much appreciated.:)
Hi
After putting the uvseams did you use the command apply uvset before bake ?
Hi Carlosan,
 Thanks for replying, I can't find that anymore? I am in the retopo room and I am in mark seams but I can't find the apply uv set option.
Edited by MartianGirl
Hadn't explained enough.
Sorry I meant to say unwrap.
Ahhh, thanks Carlosan:D I am re fiddling with the uv set and will try again. Thanks so much for the speedy replies.:)
You welcome.
Can you share the file to take a look ? PM if necessary.
18 hours ago, Carlosan said:
You welcome.
Thank you Carlosan, that is very kind of you. I have pm'd you.
May be this video help your workflow a bit
