Member Turner Posted December 21, 2018 Member Report Share Posted December 21, 2018 Hi all, I haven't used 3DCoat much, so decided to go through the tutorials. In the "Primitives" tutorial, it asks me to "Select on of the primitives type on the top panel by clicking on it", which I do. (It seems to only respond if you click the pre-selected primitive.) Then, it instructs "Press the highlighted button to APPLY the primitive" - but there is no button highlighted. If I hit the "Apply" button in Tool Options, it seems to let me use the arrow to continue, but after the third one, it says "Mission has not been completed." What am I missing? thanks Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 21, 2018 Report Share Posted December 21, 2018 Hi Click Apply on Tool Options window popup. Quote Link to comment Share on other sites More sharing options...
Member Turner Posted December 21, 2018 Author Member Report Share Posted December 21, 2018 28 minutes ago, Carlosan said: Hi Click Apply on Tool Options window popup. Hi Carlosan - as noted above, "If I hit the "Apply" button in Tool Options, it seems to let me use the arrow to continue, but after the third one, it says "Mission has not been completed." In other words, that doesn't work. It's also not highlighted, but that's a different matter... Thanks! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 21, 2018 Report Share Posted December 21, 2018 Sorry i misunderstood. Are you using latest version ? Quote Link to comment Share on other sites More sharing options...
Member Turner Posted December 21, 2018 Author Member Report Share Posted December 21, 2018 9 minutes ago, Carlosan said: Sorry i misunderstood. Are you using latest version ? Yes, just downloaded this morning. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 21, 2018 Report Share Posted December 21, 2018 Which primitive are you selecting ? After pick apply once, please switch to another tool. Can you see the new primitive created ? Quote Link to comment Share on other sites More sharing options...
Member Turner Posted December 21, 2018 Author Member Report Share Posted December 21, 2018 Hi Carlosan, here's what I do: 1) Click cube (highlighted) (gray cube appears) 2) Click apply 3) Instructions still say to "Press the highlighted button to APPLY the primitave" 4) Click apply ... repeats indefinitely, so: 5) Click right-arrow and it prompts to select primitive again, which is now the Ellipse 6) Press apply... cube remains highlighted in RED; repeats indefinitely 7) Press forward arrow & prompted to select Washer 8 ) Hit "apply"... repeats indefinitely 9) Hit forward arrow, get message "Mission has not been completed." Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 21, 2018 Report Share Posted December 21, 2018 Command ADD is selected ? Quote Link to comment Share on other sites More sharing options...
Member Turner Posted December 22, 2018 Author Member Report Share Posted December 22, 2018 Yes. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 22, 2018 Report Share Posted December 22, 2018 Try deleting options.xml on ...\user\Documents\3D-CoatV48 Hope it help Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 22, 2018 Report Share Posted December 22, 2018 Related videos 1 Quote Link to comment Share on other sites More sharing options...
Member Turner Posted December 22, 2018 Author Member Report Share Posted December 22, 2018 1 hour ago, Carlosan said: Try deleting options.xml on ...\user\Documents\3D-CoatV48 Hope it help Well... still didn't work, but I think I get how that tool works. I'll take a look at the tutorials you posted - thanks! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 22, 2018 Report Share Posted December 22, 2018 Finally i can replicate this issue, is a bug. Thx for point up. Bug report was successfully sent to support@3dcoat.com Quote Link to comment Share on other sites More sharing options...
