Member RonneySingh Posted July 23, 2019 Member Share Posted July 23, 2019 Hello, In order to draw something very precise I would like to not use curves directly from 3Dcoat but import them from another software. (as DesignSpark Mechanical 4.0) Does is possible ? What I want: I created a vase and I want add two ropes perfectly horizontal. But My hand is shaking and the result is bad. Desastrous result Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 23, 2019 Share Posted July 23, 2019 Quote Link to comment Share on other sites More sharing options...
New Member bellsmizzen Posted July 20, 2023 New Member Share Posted July 20, 2023 I'd want to bring in curves from another program rather than utilize the ones included into 3Dcoat. version 4.0 of DesignSpark Mechanical. Is it even possible? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 20, 2023 Share Posted July 20, 2023 Hi You can import curves from Curves menu as .eps format Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution AbnRanger Posted July 20, 2023 Reputable Contributor Solution Share Posted July 20, 2023 This post was recognized by Carlosan! AbnRanger was awarded the badge 'Great Content' and 1 points. 5 hours ago, Carlosan said: Hi You can import curves from Curves menu as .eps format I tried this successfully on a project where the client had some SVG vector art, and I brought those into Illustrator and exported as an .eps file. Another option the user can try is to go to the FILE menu > IMPORT > CURVE AS MESH Quote Link to comment Share on other sites More sharing options...
