Member AndrewG Posted June 2, 2020 Member Report Share Posted June 2, 2020 Hi, Is there any way to make an curve point fillet or chamfer. I mean in the new curve editor. What I would like to achieve is to select one point and make it rounded corner with a desired radius. There is similar option in Cinema4D for example, and it would be really great to have it something like that in 3dCoat:) Quote Link to comment Share on other sites More sharing options...
Member AndrewG Posted June 2, 2020 Author Member Report Share Posted June 2, 2020 Ok, sorry for making a mess. I just found a solution. You need to select a point that you want to fillet and choose from menu Curves>Curves Operation>Remove Sharp Corners and tick the "Apply only to selected vertices" to work on selected vertices. Thats great! Quote Link to comment Share on other sites More sharing options...
Advanced Member Featured Comment sprayer Posted June 2, 2020 Advanced Member Featured Comment Report Share Posted June 2, 2020 Yes it can be renamed to - add fillets =) Quote Link to comment Share on other sites More sharing options...
Member AndrewG Posted June 2, 2020 Author Member Report Share Posted June 2, 2020 1 hour ago, sprayer said: Yes it can be renamed to - add fillets =) Yep. Adding some nice shortcut would be nice too. Not sure why, but I cant add any defined shortcuts to Curves menu. Quote Link to comment Share on other sites More sharing options...
Posted by sprayer,
0 reactions
Go to this post
