Advanced Member pickers Posted August 18, 2020 Advanced Member Report Share Posted August 18, 2020 How to move the vertices and edges according to the neighbouring vertices and edges automatically? I have tried 1) relax 2) delete the faces and RFill Both methods are just averaging out the spaces and not giving me the correctly alignment. Scale tool do work for faces in the correct orientation but failed at organic shapes. So what other methods can solve this issue? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 19, 2020 Report Share Posted August 19, 2020 What if you use transform Tool on UV preview ? Quote Link to comment Share on other sites More sharing options...
Advanced Member pickers Posted August 21, 2020 Author Advanced Member Report Share Posted August 21, 2020 i have found a less than ideal solution which is to delete the faces then "hard" stroke the points. Quote Link to comment Share on other sites More sharing options...
