Right Click on a shader.
You can adjust a shader temporary or permanent.
I would not replace any image files if you are only temporary adjusting the shader. My recommendation as that does remain permanent.
Temporary is only that, Once you have made the adjustments and the shader is no longer selected, the shader goes back to it's default settings.
Of course you can create your own shader as well.
Posted by digman,
0 reactions
Go to this post
