Member 3D_COAT_user Posted December 24, 2020 Member Report Share Posted December 24, 2020 Подскажите пожалуйста, как скрыть часть геометрии в скульпт-рум чтобы разгрузить вьюпорт и легко работать с многомилионной геометрией? Quote Link to comment Share on other sites More sharing options...
Member 3D_COAT_user Posted December 24, 2020 Author Member Report Share Posted December 24, 2020 Уточню - в сюрфейсах как можно инвертировать захват инструмента сюрфейс хайт? шифт+альт не работает так как в вокселях Quote Link to comment Share on other sites More sharing options...
Advanced Member sprayer Posted December 24, 2020 Advanced Member Report Share Posted December 24, 2020 Quote Link to comment Share on other sites More sharing options...
Member 3D_COAT_user Posted December 24, 2020 Author Member Report Share Posted December 24, 2020 1 hour ago, sprayer said: Спасибо! Quote Link to comment Share on other sites More sharing options...
Member 3D_COAT_user Posted December 24, 2020 Author Member Report Share Posted December 24, 2020 1 hour ago, sprayer said: блин, я в этом режиме попробовал слить с шифтом слои и все исчезло( ни ктрл+z ни автосейв проблему не решил. Блин запорол всю работу. Ничего незя сделать в таком случае? Quote Link to comment Share on other sites More sharing options...
Member 3D_COAT_user Posted December 24, 2020 Author Member Report Share Posted December 24, 2020 Где кстати настроить контрал+з чтобы можно откатываться назад нормально хотя бы на 30 шагов? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 24, 2020 Report Share Posted December 24, 2020 Hello, hope it help This video demonstrates the usage of the Vox Hide tool; a very powerful Voxel Modeling feature. NOTE: This tool has since been re-located to the BRUSHES section of the Tool Panel, where it is more logically positioned. Quote Link to comment Share on other sites More sharing options...
Member 3D_COAT_user Posted December 25, 2020 Author Member Report Share Posted December 25, 2020 2 часа назад Карлосан сказал: Привет, надеюсь, это поможет Это видео демонстрирует использование инструмента Vox Hide; очень мощная функция моделирования вокселей. ПРИМЕЧАНИЕ. С тех пор этот инструмент был перемещен в раздел КИСТИ на Панели инструментов, где он расположен более логично. Да, дело было в плотности сетки, спасибо, надо это взять на заметку. По этой же причине Коат не смог откатить сцену назад через ктрл+з ? с этим тоже часто сталкиваюсь Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 25, 2020 Report Share Posted December 25, 2020 Could be Are you using latest version 4.9.68 ? Quote Link to comment Share on other sites More sharing options...
Member 3D_COAT_user Posted December 25, 2020 Author Member Report Share Posted December 25, 2020 14 minutes ago, Carlosan said: Could be Are you using latest version 4.9.68 ? I am using version 4.9.53 ? Does it matter? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 25, 2020 Report Share Posted December 25, 2020 No, problems with vox hide were fixed in previous versions 4.9.52 Fixed problems related to 3D-lasso + hide 4.9.49 Unhide with CTRL+lasso problem fixed. Quote Link to comment Share on other sites More sharing options...
Member 3D_COAT_user Posted December 25, 2020 Author Member Report Share Posted December 25, 2020 5 hours ago, Carlosan said: No, problems with vox hide were fixed in previous versions 4.9.52 Fixed problems related to 3D-lasso + hide 4.9.49 Unhide with CTRL+lasso problem fixed. Thank you Quote Link to comment Share on other sites More sharing options...
Member 3D_COAT_user Posted December 25, 2020 Author Member Report Share Posted December 25, 2020 Подскажите пожалуйста, где настроить клиппинг чтобы камера не обрезала объекты? Quote Link to comment Share on other sites More sharing options...
Advanced Member sprayer Posted December 25, 2020 Advanced Member Report Share Posted December 25, 2020 https://3dcoat.com/forum/index.php?/topic/15832-solved-near-camera-clipping/&do=findComment&comment=148996 Quote Link to comment Share on other sites More sharing options...
Member 3D_COAT_user Posted December 25, 2020 Author Member Report Share Posted December 25, 2020 1 hour ago, sprayer said: https://3dcoat.com/forum/index.php?/topic/15832-solved-near-camera-clipping/&do=findComment&comment=148996 I don't see it here. Near Plane Modulator not work. Quote Link to comment Share on other sites More sharing options...
Advanced Member sprayer Posted December 26, 2020 Advanced Member Report Share Posted December 26, 2020 Then use orthographic view Quote Link to comment Share on other sites More sharing options...
