3DCoat 2021.21 (mac) migration master fails
If I leave preferences folder (in documents) from previous build so it gets overwritten, will my brushes/smart materials/ui setup etc still be present.
Usually I add _old to the folder so a new one is created (which was), then migrate from the _old folder.
Edited by MarkC
UPDATE:
When I select something to migrate, 3D Coat restarts immediately (where normally it would install the data then restart).
Migration works fine from V4.
However if your a new user with 2021 this is not ideal.
Fortunately I had not changed anything within 2021 since my initial migration, so all good, but a pain in the butt to manually install extensions (smart materials from pbr store), one at a time.
Edited by MarkC
  • Carlosan changed the title to 3DCoat 2021.21 (mac) migration master fails
  • 1 month later...
Version 2021.50
- Fixed problem related to migration master. First, the default source path is correct now. Second, copying smart materials is now correct, there was problem if the images was in folders named using the native language characters. The 4.9 uses ACP, 2021.xx uses UTF-8, so there was incompatibility in textures names. Now names converted correctly.
  • Carlosan changed the title to [Fixed] 3DCoat 2021.21 (mac) migration master fails
Version 2021.51 Mac Mojave (10.14)
Migration master still not working from a 2021 build. 3D Coat closes immediately after hitting migrate.
If migrating from V4.9, it takes a good few minutes to bring in the assets, then restarts with the migrated files loaded.
