Advanced Member ghib Posted May 26, 2009 Advanced Member Report Share Posted May 26, 2009 Just tested the latest Alpha-86[RC] and the Edit all layers in Ext Editor and it occurred to me that the Normalmap layers are imported as Standard Blend. Would it be possible to automatically set any layers with Normalmap in the name to Normal Map blend mode on re-import? Everytime you use 'Add Layer with Normal Map' function it creates the Layer with the name Normalmap so as long as it's not changed it might be a logical thing to help speed up the workflow. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted May 27, 2009 Report Share Posted May 27, 2009 Just tested the latest Alpha-86[RC] and the Edit all layers in Ext Editor and it occurred to me that the Normalmap layers are imported as Standard Blend. Would it be possible to automatically set any layers with Normalmap in the name to Normal Map blend mode on re-import?Everytime you use 'Add Layer with Normal Map' function it creates the Layer with the name Normalmap so as long as it's not changed it might be a logical thing to help speed up the workflow. Ok, that is easy. Quote Link to comment Share on other sites More sharing options...
Advanced Member ghib Posted May 28, 2009 Author Advanced Member Report Share Posted May 28, 2009 Just caught from your Twitter page that you'd implemented this already. Thumbs up, so fast. Quote Link to comment Share on other sites More sharing options...
