Member Omni-Moulage Posted February 27, 2022 Member Report Share Posted February 27, 2022 Hello, In order to decorate an helmet I would like use repetive pattern with the tool "curve". But that works well for existing patterns and not for the new one I created. The problem is this new pattern doesn't stick on the surface of the helmet. I have several questions: Does the "Curve" tool is the correct way for that ? If not what will be the correct tool ? If yes what is wrong with my method ? And also how is possible to place the Red bubble of the curve tool at 0.00mm (front view) ? I have prepared an short video to show you my screen. https://drive.google.com/file/d/1M7ISdDOZc6OjGIsQlr_ILu8RhRzMNxoT/view?usp=sharing Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 27, 2022 Report Share Posted February 27, 2022 You original Wheat pattern its located at 0,0,0 global space before export it ? Quote Link to comment Share on other sites More sharing options...
Member Solution Omni-Moulage Posted February 27, 2022 Author Member Solution Report Share Posted February 27, 2022 Ok Carlosan, Gizmo origin is the solution. From 3D Coat the gizmo is positionned at 0,0,0 But when I open it with 3Dbuilder it seems that it is at 0,4500,0. So I change the origin that inside 3D builder then save it. Now that work fine. Thank you 1 Quote Link to comment Share on other sites More sharing options...
