Advanced Member DustyShinigami Posted April 11, 2022 Advanced Member Share Posted April 11, 2022 Hi I'm currently on the latest build - 2022.16 - and I've noticed a couple of bugs I've encountered in previous versions are still lurking. One involves the red symmetry plane. Sometimes, it'll be there, and others - it's gone. Even with it enabled in the Symmetry options: The other issue involves the ALT key to pan the camera around. At random times, it'll stop working. Pressing a bunch of random keys/buttons in the UI can sometimes rectify it. A good example of when it happens is if you try to use ShareX to record a GIF. The ability to rotate the camera stops working, as you can see here: Quote Link to comment https://3dcoat.com/forum/index.php?/topic/26854-a-couple-of-bugs/ Share on other sites More sharing options...
New Member MArcoBal Posted April 22, 2022 New Member Share Posted April 22, 2022 Hi, I confirm I do have the same issue with the symmetry plane randomly disappearing and the curve snap to symmetry not working. I've tried 2022.16, 2022.21 and 2021.99. and it's not working. No issues with 4.9.67. I'm on windows 10 with the latest NVIDIA Studio drivers 512.15 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/26854-a-couple-of-bugs/#findComment-181160 Share on other sites More sharing options...
Carlosan Posted April 22, 2022 Share Posted April 22, 2022 Hi Symmetry plane is visible by selected layer. If the layer model selected is small that current one could be visually occluded. Try working on Global mode if you can. Hope it help Quote Link to comment https://3dcoat.com/forum/index.php?/topic/26854-a-couple-of-bugs/#findComment-181161 Share on other sites More sharing options...
New Member MArcoBal Posted April 22, 2022 New Member Share Posted April 22, 2022 54 minutes ago, Carlosan said: Hi Symmetry plane is visible by selected layer. If the layer model selected is small that current one could be visually occluded. Try working on Global mode if you can. Hope it help Thanks for this. but it doesn't work 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/26854-a-couple-of-bugs/#findComment-181162 Share on other sites More sharing options...
