Member Starship3D Posted May 25, 2022 Member Report Share Posted May 25, 2022 I created a test alpha in photoshop of 4096 x 4096 (Just the letter A on an alpha background) but inside 3D coat it looks very jagged along the edges and blurry. Is there something I have to do to make it look clear to give a clear edge when applied to a surface? Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted May 25, 2022 Solution Report Share Posted May 25, 2022 If you are working on Sculpt Mode check density or polygons, on paint room texture resolution and UV texel density. More is better Quote Link to comment Share on other sites More sharing options...
Member Starship3D Posted May 25, 2022 Author Member Report Share Posted May 25, 2022 1 hour ago, Carlosan said: If you are working on Sculpt Mode check density or polygons, on paint room texture resolution and UV texel density. More is better You mean number of tris? I've attached another image, it's about 7 million, but it still looks jagged. Should my alpha image be bigger than 4096? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 25, 2022 Report Share Posted May 25, 2022 no, can you share the pic please Quote Link to comment Share on other sites More sharing options...
