Advanced Member DMG Posted October 1, 2022 Advanced Member Share Posted October 1, 2022 (edited) I was going between 3DC and Blender a bit trying to hit the sweet spot I wanted for something, and I noticed differences between the two renders, especially caused by varying roughness values. I decided to get a bit scientific about it, so here's the results of my tinkering. I used the studio.exr panorama from Blender in both programs for a fair comparison. The 3DCoat environment settings were left at default, but the light was deactivated. The HDRI was normalised when I imported it. The HDRI strength was left at default value in Blender too. A simple sphere, identical colour value in all renders. I'm making no judgement as to which renderer is 'better'. This is just purely for comparison, to see how roughness values appear in each in order to make texturing a bit more predictable. I did notice that in the HDRI there is a tiny but bright spotlight high up adjacent to the other light, but for some reason this isn't picked up in the 3DCoat renders. Perhaps it's just a tiny pinprick and too small to be picked up. I don't know. There also appears to be a light down low, right of centre, but only on the renders for 25% to 40% roughness in the 3DCoat renders. I don't know where that's coming from. It isn't apparent in any of the others. The most noticeable differences is that the reflections in the 3DCoat Paint Room preview are a touch more intense than both of Blender's renders, but the same reflections are a bit feinter in 3DCoat's Renderer. Also, at around 35-40% roughness, the 3DCoat Renderer has greater blur on the main reflections near the centre, which has almost become a single bright patch, whereas all the others still have two distinct light sources. Like I said, this isn't about picking a 'winner' or 'favourite'. It's just to help me predict how my textured objects will appear and render in Blender to save time to-ing and fro-ing making adjustments. Just thought I'd share. Regards, Derek Edited October 2, 2022 by DMG Adding tags 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 3, 2022 Share Posted October 3, 2022 Hi On Paint room Which shader view do you have selected ? //edit GGX, Burley 12 (UE4): GGX compatible with Unreal4, 4A Games pilpeline, Disney, Unity etc.GGX, Lambert (Marmoset): GGX – compatible with Marmoset. It differs from regular GGX by lack off additional diffuse modulation.Handpaint: The best for handpainted textures. This is GGX shader with zero specularity at rough plastic. Quote Link to comment Share on other sites More sharing options...
Advanced Member DMG Posted October 3, 2022 Author Advanced Member Share Posted October 3, 2022 Hi Carlosan, I have that shader selected, the GGX Burley one. If I have time, I might expand and include the 'Handpaint' one too, but it won't be 'till the weekend at least. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member DMG Posted October 4, 2022 Author Advanced Member Share Posted October 4, 2022 I had a quick check with the 'Handpaint' Paint room render, and it at a glance, the light hotspots aren't quite as intense as the GGX ones are, so I suspect that will be closer visually to the Bender renders. Definitely worth updating my chart to include that. 1 Quote Link to comment Share on other sites More sharing options...
Advanced Member DMG Posted October 4, 2022 Author Advanced Member Share Posted October 4, 2022 Updated Chart... The rows are: 3DCoat's GGX, Handpaint, Render; then Blender's Eevee, Cycles. * I think the Handpaint render (compared to the GGX one) has slightly lower intensity in the bright highlights, as well as ever so slightly more diffuse reflections when the roughness reached mid-levels. And compared to the 3DCoat render, the bright highlights in the Handpaint render are a touch more intense, and as with the GGX ones, much more defined. Looking at the Handpaint renders and the Blender Cycles renders, they're actually very similar. This is excellent. I feel that if I use the Handpaint preview, I will be seeing a very close approximation of what I'll get in Blender. So my chart is now redundant, based on the reason I created it in the first place, but it has nevertheless been very useful. Derek 1 3 Quote Link to comment Share on other sites More sharing options...
