Member Deano C Posted January 14, 2023 Member Report Share Posted January 14, 2023 Hi, I've yet to get an auto-retopo complete, it hangs every time in an infinite loop (CPU core are busy but even if left hours doesn't complete). It seems to handle to reduction prior to the auto-topo dialog and then regardless of settings (including using the defaults and no density or guides) it will hang in the post dialog reduction. Tried with different meshes of different polygon scales etc. but it just never works. Tried characters, props and other types of things. The only thing my meshes have that most of the examples I've seen don't, is that the meshes isn't continuous and hard some hard non closed edges. Quote Link to comment Share on other sites More sharing options...
Member Deano C Posted January 14, 2023 Author Member Report Share Posted January 14, 2023 Different way, similar results. Bring a mesh into Paint Room from Blender, swap the the retopo room, hit auto-retopo, hangs at Object: Creating cut graph Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 14, 2023 Report Share Posted January 14, 2023 Try another settings, like example this one Hope it help Quote Link to comment Share on other sites More sharing options...
Member Deano C Posted January 14, 2023 Author Member Report Share Posted January 14, 2023 Exactly the same settings as you, no difference - hangs here (left it 5-10 minutes so far and there is no reason to suggest this will complete any different from other times). All the hallmarks of a cycle somewhere in the code/data Quote Link to comment Share on other sites More sharing options...
Member Deano C Posted January 14, 2023 Author Member Report Share Posted January 14, 2023 Slightly different but similar. Bring a paint mesh over from Blender, swap to Sculpt Room and bring paint mesh over to sculpt (it will come over as a surface object, all the methods to change it to voxel are also broken in various ways BTW). Right click on the object and select Retopology via decimation. Will hang and sometimes crash. Quote Link to comment Share on other sites More sharing options...
Member Deano C Posted January 14, 2023 Author Member Report Share Posted January 14, 2023 By bringing this particular mesh over from blender via the auto-retopo option Applink, I managed to get it to crash, so at least you have a probably related stack trace. The stack trace suggests it is related to having open UV edges but that just might be a false lead. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 14, 2023 Report Share Posted January 14, 2023 can you share the model to take a look ? Quote Link to comment Share on other sites More sharing options...
Member Deano C Posted January 14, 2023 Author Member Report Share Posted January 14, 2023 Not in a public place (it contains licensed material), if there is a private place I can upload it to? Quote Link to comment Share on other sites More sharing options...
Member Deano C Posted January 14, 2023 Author Member Report Share Posted January 14, 2023 I'll DM you a link once I've uploaded it. 1 Quote Link to comment Share on other sites More sharing options...
