Member SkyDiver Posted February 9, 2023 Member Report Share Posted February 9, 2023 Hi! I recently spent two days hand-painting a game character only to realize the mesh was missing teeth and some other meshes. We now have a new mesh outside of 3DC with different UVs and topology which needs to replace the old mesh within 3DC so we can continue working on it. I cannot afford to re-paint the newly imported creature by hand again, is it possible to somehow re-import the new model and retain/bake the paint layers of the old? Another texturing tool, Substance Painter, allows you to re-import any mesh with a 'preserve strokes positions on mesh' setting so the new model retains the paint layers correctly despite differing UV or mesh topology. Is there anything similar in 3DC I could do? I've been told the Texture Baking tool in the paint room is the solution, but it appears to do nothing at all. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 10, 2023 Report Share Posted February 10, 2023 Save your project before any test. You can try this command Hope this help Quote Link to comment Share on other sites More sharing options...
Member SkyDiver Posted February 10, 2023 Author Member Report Share Posted February 10, 2023 Thanks for the quick reply, I tried this and it imported, but unfortunately the paint was all messed up as the new model doesn't have a simular UV configuration. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 10, 2023 Report Share Posted February 10, 2023 I see... try Textures > Texture Baking Tool Quote Link to comment Share on other sites More sharing options...
Member SkyDiver Posted February 11, 2023 Author Member Report Share Posted February 11, 2023 Getting closer! I think the texture bake tool would work, but now something is really wrong with importing the new model! I'm not sure why this error would occur. The yellow image is what 3DC is importing, looking at the render shows only the newly added parts of the head were unwrapped for some reason, and then 3DC tried to texture bake the entire character onto that? For context, this grey image is what the same model's UVs look like when imported into Blender. 3DC's import should look like this one. Any ideas on what might cause 3DC to misinterpret UVs on import with the default settings? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 11, 2023 Report Share Posted February 11, 2023 Old bug result of UVmaps flipped on Y after import UV. Was solved on latest version 2022.60 Quote Link to comment Share on other sites More sharing options...
Member SkyDiver Posted February 11, 2023 Author Member Report Share Posted February 11, 2023 Just updated to 2022.60 and tried another re-import, same issue still occurs. At least the texture-baking tool you showed seems to work correctly/is the solution to my first problem. Is there anything I could do when exporting or importing to avoid this UV flip issue? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 12, 2023 Report Share Posted February 12, 2023 Please share the model to take a look. Quote Link to comment Share on other sites More sharing options...
Member SkyDiver Posted February 13, 2023 Author Member Report Share Posted February 13, 2023 I wouldn't be allowed to share the model publicly on a forum like this. Is there another way? Thanks for the help with the original texture bake issue though, I tried it on an unrelated test model and it will work on this one once this other issue is fixed. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 13, 2023 Report Share Posted February 13, 2023 No public, by PM Quote Link to comment Share on other sites More sharing options...
Member SkyDiver Posted February 13, 2023 Author Member Report Share Posted February 13, 2023 I managed to fix the issue! It turns out the fbx export still has the issue, but obj files are OK. Now that the new mesh is correctly in 3DC, I tried the texture baking tool with these settings and it is outputting a blank/grey maps (as opposed to my hand-painted texture). I was following along with the video you posted earlier, but it appears I am doing something wrong. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 16, 2023 Report Share Posted February 16, 2023 Everything looks ok, inward/outward values are ok ? Quote Link to comment Share on other sites More sharing options...
