Member giobianco63 Posted April 4, 2023 Member Report Share Posted April 4, 2023 (edited) Hi, when I change the brush image to another the new one has the wrong size compared to the brush size, to bring it back to the correct size I have to make a change of tool (example switching to the FILL TOOL) by repeating the action at least twice and at that point the size of the image used for the brush is correct. this bug already existed from the first versions and unfortunately it is still present in the version 2023.11 3DCoatTextura. Giovanni Edited April 5, 2023 by giobianco63 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 5, 2023 Report Share Posted April 5, 2023 Try activating "Remember..." option on Preferences Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted April 5, 2023 Author Member Report Share Posted April 5, 2023 11 hours ago, Carlosan said: Try activating "Remember..." option on Preferences Hi, the remember items are active, but the problem is still there, I attach a couple of screens 1 Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted April 5, 2023 Author Member Report Share Posted April 5, 2023 the problem is alwaye present in version 2023.13 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 5, 2023 Report Share Posted April 5, 2023 please share this alpha, is bmp png tif... ? i cant replicate sorry Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted April 5, 2023 Author Member Report Share Posted April 5, 2023 (edited) Hi, Sorry...but it's not a problem of this particular image.... it does it randomly with any image.. I took the scene of the cube, I randomly chose a series of about fifteen images.. and they all worked correctly... at the sixteenth I started to encounter this bug. Giovanni Edited April 5, 2023 by giobianco63 1 Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted April 28, 2023 Report Share Posted April 28, 2023 On 4/6/2023 at 1:50 AM, giobianco63 said: I took the scene of the cube, I randomly chose a series of about fifteen images.. and they all worked correctly... at the sixteenth I started to encounter this bug. I tried all alphas, several times. Can't repeat this mistake. In any case, at 23.17 this is not repeated. Please write if the problem is still present in the latest version. Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted April 30, 2023 Author Member Report Share Posted April 30, 2023 (edited) Hi, sorry but it also repeats on version 2023.17. I did this sequence: 1) I took the cube as a mesh. 2) picked up a brush at random, and this works fine. 3) I change the brush image to another one and..... the painted result of the brush has a different bigger size. Giobianco Edited April 30, 2023 by giobianco63 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted April 30, 2023 Report Share Posted April 30, 2023 On version 2023.18 everything is working as expected. Ii is only happening with your's custom brushes ? Try using any other default brush Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted May 7, 2023 Author Member Report Share Posted May 7, 2023 Hi, in version 2023.18 the brush problem is still there. I tried with the default brushes of the program and they work correctly. my brushes are square PNGs. Giovanni 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 7, 2023 Report Share Posted May 7, 2023 please share one of this brushes with issues Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted May 7, 2023 Author Member Report Share Posted May 7, 2023 (edited) Hi, this is one of the PNG files. (I also add the ZIP file) Giovanni 14_alonso_03.7z Edited May 7, 2023 by giobianco63 1 Quote Link to comment Share on other sites More sharing options...
Oleg Shapov Posted May 7, 2023 Report Share Posted May 7, 2023 1 hour ago, giobianco63 said: this is one of the PNG files Confirmed. Reported. Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted December 30, 2023 Author Member Report Share Posted December 30, 2023 Do you know if this bug will be fixed? because in version 2023.41 of 3dcoattexture it is still present. I take this opportunity to wish everyone a happy holiday season. Best Regards Giovanni 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 30, 2023 Report Share Posted December 30, 2023 I tested it and still it is not solved 1 Quote Link to comment Share on other sites More sharing options...
Member giobianco63 Posted 12 hours ago Author Member Report Share Posted 12 hours ago Do you know if this bug will be fixed? because in version 2024 of 3dcoattextura it is still present. Quote Link to comment Share on other sites More sharing options...
