Member bcgreen24 Posted July 13, 2023 Member Report Share Posted July 13, 2023 (edited) Is this how it's supposed to work, or is this a bug? When I have a cube in front orthographic view and paint a face, color ends up getting applied to all the adjacent faces.... Thanks, Bryan Edited July 13, 2023 by bcgreen24 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 13, 2023 Report Share Posted July 13, 2023 Are you using the default cube ? If not try with any default model at startup Quote Link to comment Share on other sites More sharing options...
Member bcgreen24 Posted July 13, 2023 Author Member Report Share Posted July 13, 2023 Yes Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 13, 2023 Report Share Posted July 13, 2023 Sorry, i dont know how to replicate this issue. Testing 2023.23 it is working as expected Quote Link to comment Share on other sites More sharing options...
Member bcgreen24 Posted July 13, 2023 Author Member Report Share Posted July 13, 2023 The issue is not that I can't paint on the object (as you can see in my screenshot)...the issue is that when I am in an orthographic view, I would expect to be able to paint on a cube's surface without the paint affecting the adjacent faces. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 14, 2023 Report Share Posted July 14, 2023 The brush follow mesh contour, Since the edges are not perfectly flat but rather the model has a bevel, the painting accommodates following the geometry. Try single polygon stroke, it will help Quote Link to comment Share on other sites More sharing options...
