[Solved] How do I disable Sticky Keys ?
ijac
I have custom hotkeys for most of my retopo tools that I use.  I don't use Stack Keys or Sticky Keys.  There is a function of Sticky Keys that I really, really dislike.
The problem ... I have D assigned to the Points to Polygons tool.  When I press D multiple times it switches to the last tool I used, then back to Points to Polygons tool.  I hate this :D When I press D I want to know that it's selecting the Points to Polygons tool and nothing else ... ever.   I assume this is part of the Sticky Keys functions.
How do I disable Sticky Keys?
Thanks for your help :)
Edited by ijac
:huh: That's not intended behavior, and sounds like a bug. Which build are you using ?
There is a workaround which could be useful
Export hotkeys from [Edit] - [save hotkeys].
Open it with text editor, replace all
<AllowStack>true</AllowStack>
to
 <AllowStack>false</AllowStack>
And reimport
Carlosan
ijac was awarded the badge 'Great Support' and 1 points.
Thanks for the info.
I was seeing this in 2023.16.  I just updated to 2023.29 and the behavior is the same.  Nothing has changed.
I exported the hotkey file and did as you explained.  Most were already set to False.  Only one was set to True.  I changed it to False and reimported the hotkeys.  The behavior is still the same.  Nothing has changed.
It's behaving exactly as described in the official Sticky Keys video ... 3:12 minute mark.  This is what I want to disable.
Same problem for me (sticky keys), which I had already reported/requested some time ago. Thanks for this report.
Edited by rubeos
  • 4 months later...
  • Carlosan changed the title to [Solved] How do I disable Sticky Keys ?
Posted (edited)
As of v2024.13 this is not solved.  Behavior hasn't changed at all.  I have "Don't Use Sticky Key" checked on in Preferences.  I restarted 3D Coat after checking it on fyi
Edited by ijac
