Advanced Member pieralessi Posted October 11, 2023 Advanced Member Report Share Posted October 11, 2023 (edited) Hi, wen I us CTRL+Z command this no works, only if I go to the Edit menu in the menus bar. Window 10, the language is just in English Edited October 11, 2023 by pieralessi more deatails Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 11, 2023 Report Share Posted October 11, 2023 Try installing a fresh install of version 2023.31 Quote Link to comment Share on other sites More sharing options...
Advanced Member pieralessi Posted October 11, 2023 Author Advanced Member Report Share Posted October 11, 2023 I updated it just you published the update Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 11, 2023 Report Share Posted October 11, 2023 When you use ctrl+z... doing which steps ? Could you please detail your current workflow so I can try to replicate it ? Quote Link to comment Share on other sites More sharing options...
Advanced Member pieralessi Posted October 11, 2023 Author Advanced Member Report Share Posted October 11, 2023 Are various situations such back to a new position the primitive or wherever situation, only works with mouse, no with keyboard, other functions work well on keyboard. Quote Link to comment Share on other sites More sharing options...
Advanced Member pieralessi Posted October 12, 2023 Author Advanced Member Report Share Posted October 12, 2023 Is there a way to avoid this? She had done it before and now after having explored everything I can't understand why the Twist looks so bad. Please respond shortly, I lost this job. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 12, 2023 Report Share Posted October 12, 2023 Whit 61000 tris this is the result that I get Please add a pic pressing W to look at model density topology Quote Link to comment Share on other sites More sharing options...
Advanced Member pieralessi Posted October 12, 2023 Author Advanced Member Report Share Posted October 12, 2023 Quote Link to comment Share on other sites More sharing options...
Advanced Member pieralessi Posted October 12, 2023 Author Advanced Member Report Share Posted October 12, 2023 The problem is not the finiture but the twist is not centered, it seem a circus Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 12, 2023 Report Share Posted October 12, 2023 your model need more edges at Z axis It have not enough resolution Example: Quote Link to comment Share on other sites More sharing options...
Advanced Member pieralessi Posted October 12, 2023 Author Advanced Member Report Share Posted October 12, 2023 I put more resolution and made another problems, I used other ways to do it I don't remember, Now the adjust tool disappeared Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 1, 2023 Report Share Posted November 1, 2023 Try reset settings command (under Edit menu) or Windows > Customize UI Locate Adjust section and select Un-hide section Quote Link to comment Share on other sites More sharing options...
