problem with text editor
Go to solution Solved by digman,
  • Solution
Your first control point for your curve seems to be off plane a few times. I noticed at the last you had it working for a moment.
Try this to fix your problem.
Since this is a rectangular type of model and it appears, you are not trying to wrap a text around a corner, have the view lined up correctly before placing your first control point.
Press the ESC key to clear the curve.
Do not start the curve right at the sharp edge of the model. Make sure the cursor is on the correct plane before placing the first control point.
My picture shows the first control point is starting on the wrong plane. Blue line points to the control point.
Side Note: Use the e-panel brush shown in the picture. It will help to create the text placement correctly when applying the text.
I hope the above is helpful.
After more investigation, it seems not totally corrected.
Because with the smallest size of the radius, with any kind of brush stroke,
I have the same problem on a small model, whitch i click in the middle of the face and the circle doesn't look facing it, and the second near the border neither,
And moving a little the marks makes it moves like on the video.
