I imported a model with many different parts to 3d Coat Textura. Knowing that each have to have its own material in order to keep the UVs separate, I just made random Lamberts for each one, didn't bother renaming them. After I finish doing all my textures in Textura I go to Texture --> Export --> Color/albedo Map. In the prompt that appears I choose to export all textures. I actually had gone through all the shaders and renamed them in the Surface material window of 3d Coat Textura but upon export I realized that it takes the lamberts sg node as the suffix. Is there a way to change this behavior or would I have to go back to the original 3D software rename all the shaders and then do the texturing process all over again?
Question
oiver55
1 answer to this question
