Is there an easier way to do this?
ShnitzelKiller
Use a curve, hold Cntrl while pressing Enter.
Oh, thanks. I didn't know you could fill curves. I just wish the handles were easier to manipulate; after you add them, you can't slide them on the surface anymore, but have to use those transform widgets. I like the way the splines in painting work (especially the right click scaling), and would love for these to be the same way. It's easy to accidentally add a point on the curve when you miss a widget D:
EDIT: I just discovered what happens when you hold control with the move tool... if you're using a solid brush, then movement along the surface normal is pretty useful for simple shaped holes / bumps.
It's pretty cool that it can detect surface normal at all, being a voxel.
