Advanced Member Ratchet Posted October 8, 2009 Advanced Member Report Share Posted October 8, 2009 Well , when sculpting in voxels using symmetry, we use symmetry for retopology. -It would be really great to have symmetry fro the low poly model made from retopology in paint mode ! -And possibility to export the complete low poly model , not only one part of the symmetry ! The vertex of symmetry of the low poly model would be joined automatically ! Would be really a great time gain : caus that you , you won't have to export to another application, to make the complete model from the half of the symmetry. Another point : it could allow us to see if the generated normal map for the low poly model is ok on the edges of the symmetry : no seams ! Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted October 8, 2009 Contributor Report Share Posted October 8, 2009 Andrew if when user press Apply Symmetry with an already Unwrapped piece of topology 3DCoat would copy/overlap the Uvs at the same time when applying the topology symmetry I think it would do the trick. Quote Link to comment Share on other sites More sharing options...
