Member Flytronik Posted February 26, 2010 Member Report Share Posted February 26, 2010 Push, sorry i don't can wait. http://www.3d-coat.com/forum/index.php?showtopic=5219 Quote Link to comment Share on other sites More sharing options...
Member Helmut S. Posted March 7, 2010 Member Report Share Posted March 7, 2010 This looks exactly like the problem I posted here a while ago: http://www.3d-coat.com/forum/index.php?showtopic=4637 Good for me: you don't use Kubuntu, so the number of affected platforms seems to have increased by one for now ... maybe this makes it easier to nail that bug down, finally. I would still be very glad for a fix as well - in fact I had no further use for 3DC since I reported the problem, because I can't import anything, and just switching the OS is no option at this point ... a very unsatisfying situation. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted March 8, 2010 Report Share Posted March 8, 2010 Out Linux programmer discovers this issue. It is rather not easy. Actually it is longstanding unsolved problem. He will write some report there soon. Quote Link to comment Share on other sites More sharing options...
SERGYI Posted March 14, 2010 Report Share Posted March 14, 2010 Hello Flytronik! Thanks for your participation. I was messing around with openSUSE 11.2 (64 bit) and 3d-coat for several days. As you may know, the NVIDIA driver isnt integrated into openSUSE because of license. There are two ways to get NVIDIA driver: through repository or with manual compile. The last option strictly requires the same header files and libraries which were used during kernel compilation (http://en.opensuse.org/NVIDIA/The_hard_way). So within YaST->Software>Software Repositories->Add I added repository http://download.nvidia.com/opensuse/11.2/ . Then launched YaST->Software->Software Management. The driver x11-video-nvidiaG02 for my NVIDIA GeForce 8800 was automatically selected, as well as new kernel file. After installing no issues with 3d-coat were discovered (see attached screenshots for microvertex mode, per pixel painting, reference mesh option, and voxel sculpting with manipulators). Such issues with 3d-coat under Linux have been reported several times on this forum, but after installing Linux version specified by the user we were unable to reproduce the glitches. Therefore I think that such cases are related to improper video driver operation (maybe with such trivial things like vertex attributes input from vertex buffer within vertex shader). Please try to use specified repository to get driver. Quote Link to comment Share on other sites More sharing options...
Member Flytronik Posted August 28, 2010 Author Member Report Share Posted August 28, 2010 Hello SERGYI, i work 15 years with Linux an the last NVIDIA Driver is install. I upload a Video then you can see. http://www.flytronik.de/video/out.ogv EDIT: I have now a GTS 250 8GB Ram 12 GB Swap AMD X4 9950 OpenSuSe 11.2 64 bit I have test fedora 13, Kubuntu 10.04 and Mandriva 2010.1 the same problem. Houdini, Maya and Blender works fine. Quote Link to comment Share on other sites More sharing options...
Member Flytronik Posted August 30, 2010 Author Member Report Share Posted August 30, 2010 Can you help this? 3d-coat-64: 3D-Coat/SubdLimit.cpp:325: void PerformLimitSubdivision(PolyMesh*): Zusicherung »0« nicht erfüllt. german Quote Link to comment Share on other sites More sharing options...
Member Flytronik Posted September 18, 2010 Author Member Report Share Posted September 18, 2010 I have solved the problem, I have today Luxrender installed 0.8 and had it on gclibc 2:11 ,OpenCL update and install. Now I have no problems with 3D Coat with Linux. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 19, 2010 Report Share Posted September 19, 2010 I have solved the problem, I have today Luxrender installed 0.8 and had it on gclibc 2:11 ,OpenCL update and install. Now I have no problems with 3D Coat with Linux. Very good! Quote Link to comment Share on other sites More sharing options...
Member Flytronik Posted September 19, 2010 Author Member Report Share Posted September 19, 2010 Very good! I have test it! This is not the glibc, i have switch my language to english and it works. The problem is the locale de_de.UTF8. After the reboot with de_de.utf8 it have the same problem. Quote Link to comment Share on other sites More sharing options...
Member Flytronik Posted September 30, 2010 Author Member Report Share Posted September 30, 2010 19. September, 11 days and no bugfix, painful. Quote Link to comment Share on other sites More sharing options...
Member Flytronik Posted October 4, 2010 Author Member Report Share Posted October 4, 2010 15 days and no bugfix Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 5, 2010 Report Share Posted October 5, 2010 15 days and no bugfix Excuse, I just seen it, forwarded to Sergyi. Please write to support or to Sergyi directly, it will get much much faster response especially because of very specific problem. Quote Link to comment Share on other sites More sharing options...
SERGYI Posted October 22, 2010 Report Share Posted October 22, 2010 Hello, Linux users! Thanks to Flytronik, several days ago we fixed old and critical bug on some Linux systems, 3D-Coat had distorted manipulators, distorted models after any import from obj files, and crashed from time to time. As it turned out, the problem was because of standard C library function atof (converts ASCII strings to float values). When system language is other than English, atof uses comma instead of point as decimal separator. In every place of 3D-Coat, where atof function has been used, under non English Linux systems we get incorrect results when converting strings to floats. The latest version of 3D-Coat on the FTP server should work correctly regardless of system language. So everyone, who has such critical problems on non English Linux systems, please download the latest version of 3D-Coat! Quote Link to comment Share on other sites More sharing options...
