Advanced Member bobzilla Posted April 25, 2010 Advanced Member Report Share Posted April 25, 2010 Can the default color of an imported mesh be changed, just for working purposes, not to necessarily keep as a color on the mesh. And, with the selection of three different color schemes at the start of the program, why does the dark scheme and light scheme both look the same? Bob Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted April 26, 2010 Reputable Contributor Report Share Posted April 26, 2010 If you are using the default shader you can use the color picker to change the color of your voxel model. In the paint room under the Windows/popup menu choose color picker. It will stay open in the voxel room when you return and you can change the voxel model color dynamically. I have not messed around with the dark or light schemes myself. I just changed the background color by going to camera/background and choosing the top color and bottom color as the same color to get away from the gradient background. That does not anwser your question but hope it might helps some... Quote Link to comment Share on other sites More sharing options...
Advanced Member bobzilla Posted April 26, 2010 Author Advanced Member Report Share Posted April 26, 2010 OK. I'm not in the voxel room. Just bringing in mesh to paint/texture. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted April 26, 2010 Reputable Contributor Report Share Posted April 26, 2010 Darn, I keep forgetting.You could use the bucket fill tool to change the model's entire color and that is the paint room... Quote Link to comment Share on other sites More sharing options...
Javis Posted April 26, 2010 Report Share Posted April 26, 2010 And, with the selection of three different color schemes at the start of the program, why does the dark scheme and light scheme both look the same? Bob That's a bug. I can confirm it. Quote Link to comment Share on other sites More sharing options...
