Member hhal9000 Posted November 6, 2010 Member Report Share Posted November 6, 2010 I'm trying to add alpha brushes but can't seem to change the diameter of the alpha.I want to add brushes(pens?) that resemble those found in ealier versions of 3dcoat which have a sharper falloff and larger diameter. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted November 6, 2010 Reputable Contributor Report Share Posted November 6, 2010 I'm trying to add alpha brushes but can't seem to change the diameter of the alpha.I want to add brushes(pens?) that resemble those found in ealier versions of 3dcoat which have a sharper falloff and larger diameter. I had an issue recently on my laptop, where all the brush alpha's were nearly identical...unlike the standard brushes you point out there. I deleted the options.xml file (in MY DOCUMENTS> 3D-CoatV3) and re-installed the latest version of 3DC, and it took care of the problem. Is that roughly what you're experiencing? Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted November 6, 2010 Report Share Posted November 6, 2010 Try adjusting the falloff slider along the top of the screen, I normally have it set at 0% which should show the entire brush. Quote Link to comment Share on other sites More sharing options...
Member hhal9000 Posted November 6, 2010 Author Member Report Share Posted November 6, 2010 I had an issue recently on my laptop, where all the brush alpha's were nearly identical...unlike the standard brushes you point out there. I deleted the options.xml file (in MY DOCUMENTS> 3D-CoatV3) and re-installed the latest version of 3DC, and it took care of the problem. Is that roughly what you're experiencing? Looks like I may be experiencing the same problem.Yes.I thought that the alphas may have been changed in 3.5 but you're saying they should be the same as in 3.Is that right?I will try your solution .Thanks Quote Link to comment Share on other sites More sharing options...
Member hhal9000 Posted November 7, 2010 Author Member Report Share Posted November 7, 2010 Just deleted the options .xml file and reinstalled 3d coat and got all the standard brushes back.Great.Thanks AbnRanger. Thanks philnolan3d but I did allready play with the fall-off. Quote Link to comment Share on other sites More sharing options...
