Member jimiclay Posted January 2, 2011 Member Report Share Posted January 2, 2011 I'm confused by the transform tool video on the 3DCoat website voxel tutorial. Which one is it? What I get, and what the video shows are two different things. What I'm trying to do is taper a cylinder along the y axis, so that its shorter on the top end and wider on the bottom end. But the pose tool doesn't work at all, and the transform tool just moves the object. Which way does it go? Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 2, 2011 Report Share Posted January 2, 2011 Did you make a selection to use with the Pose tool? I was just using it yesterday and it was fine here. Quote Link to comment Share on other sites More sharing options...
Psmith Posted January 2, 2011 Report Share Posted January 2, 2011 It is confusing, isn't it. What you are looking for is found by using the "Primitives" tool in the Voxel toolbar. Just select the topmost "Cylinder" primitive. This one has the controls for slimming it down, altogether, or just on one end. Greg Smith Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 2, 2011 Report Share Posted January 2, 2011 Here's a quick little video showing the Cylinder primitive, then using the Pose tool on a cylinder. http://screencast.com/t/zu10nsPO Quote Link to comment Share on other sites More sharing options...
Member jimiclay Posted January 2, 2011 Author Member Report Share Posted January 2, 2011 Phil, I'm not sure I understand your question. I did what you see in the image, which was to created a cylinder with the primitives tool and select the pose tool to try and deform it. Greg, thanks for your making it a little clearer for me. But what you're not saying is really bothering me. First off, did I do something wrong? Does the pose tool work or not? I still don't understand. Furthermore, what I did do was use the freeform primitive to deform the cylinder. Again, which tool is it that we're talking about? Is the transform tool the same thing as the pose tool? or are they distinct? I'm just trying to understand. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 2, 2011 Report Share Posted January 2, 2011 The Pose tool requires you to make a selection on the model, in this case I use the "Line" type of selection which makes a gradient similar to making one in Photoshop. Perhaps it's easier to see with a different shader. Some shaders are just black, others have this rainbow look. http://screencast.com/t/xZoIy99lJN Quote Link to comment Share on other sites More sharing options...
Member jimiclay Posted January 2, 2011 Author Member Report Share Posted January 2, 2011 The Pose tool requires you to make a selection on the model, in this case I use the "Line" type of selection which makes a gradient similar to making one in Photoshop. Perhaps it's easier to see with a different shader. Some shaders are just black, others have this rainbow look. http://screencast.com/t/xZoIy99lJN Thanks Phil, U DA MAN! Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted January 2, 2011 Report Share Posted January 2, 2011 Greg helped too. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted January 2, 2011 Reputable Contributor Report Share Posted January 2, 2011 Here is a picture using the free form cylinder with the control cage. In the picture I'm in orthographic mode. Quote Link to comment Share on other sites More sharing options...
