Advanced Member wailingmonkey Posted January 27, 2008 Advanced Member Report Share Posted January 27, 2008 some more feature requests (as of 2.05beta1): - Draw with Spline tool...add the option of 'to square' in addition to the 'to circle' where it would select the most likely points as candidates for corners (based from percentage between first and and last point?) and then line up points in-between in 90-degree lines off those points. I could see also being able to select the corners manually via some hotkey and using that as a basis for square as well, which would open up the option of rectangular or trapezoidal shapes as well. - Option to 'Close Spline' with the Draw with Spline tool ... I like the added power of this tool over just using the 'Draw with Lines' or 'Draw with Curves' option on the pen tool for some things, but it would be nice to create closed spline curves with it too. - Some more attention to the 'Soft Stroke' option...still seems to leave sporadic marks (although for the most part, it now seems to stop when letting off of the left-mouse button--haven't tried tablet yet). It might also be a good option for the user to set how 'soft' the stroke will be in a range from almost no softness (like normal stroke) to highly controlled softness (the user's stroke is highly smoothed out). Also, really nice work with the additional allowance of higher polys, Andrew! It results in better texture exports all around. Adaptive geometry seems to be a great addition as well! In regard to the measure tool, did you have some suggestions as to how best to use it? I found it to be handy in measuring depth of previous displacements (good to get close to same depth, if necessary) but wondered if you had some additional ideas about it's usage? Anyhow, great job on the continual improvement of 3d-brush! Kind regards. wailingmonkey Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted January 30, 2008 Report Share Posted January 30, 2008 Now I am working over spline improvements. Will do at least closed curves and sharp edges. I paln to do 2 buttons like "Make sharp" and "Make soft" to mark some points like sharp or soft. Quote Link to comment Share on other sites More sharing options...
Advanced Member wailingmonkey Posted February 23, 2008 Author Advanced Member Report Share Posted February 23, 2008 Hi Andrew, I posted this in another thread, but thought I should post here too in case you missed it. Would you be able to add the ability to erase with the 'Draw with Spline' tool? (this can already be mostly done with the eraser tool and 'Paint with Spline', but I think adding it as a functional checkbox in 'Draw with Spline' titled 'Erase with Spline' or something would add the ability to use Spacing, which could be quite powerful in the creation of inorganic linework/detail.) cheers. wailingmonkey Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 24, 2008 Report Share Posted February 24, 2008 Hi Andrew,I posted this in another thread, but thought I should post here too in case you missed it. Would you be able to add the ability to erase with the 'Draw with Spline' tool? (this can already be mostly done with the eraser tool and 'Paint with Spline', but I think adding it as a functional checkbox in 'Draw with Spline' titled 'Erase with Spline' or something would add the ability to use Spacing, which could be quite powerful in the creation of inorganic linework/detail.) cheers. wailingmonkey I think to add checker "[x] Erase with spline" or droplist Draw/erase/freeze. I am not sure that "freeze/unfreeze with spline" is useful... Quote Link to comment Share on other sites More sharing options...
