Member Chuckpie Posted January 28, 2008 Member Report Share Posted January 28, 2008 Now that you have added a measurement tool in 2.05 beta 1, could you add a check box in the options area to select between metric and USA standards( feet, inches, etc.) Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted January 29, 2008 Report Share Posted January 29, 2008 The problem is that I don't know initial units. If I have 1 unit of coordinale, how many meters is it? Quote Link to comment Share on other sites More sharing options...
Member Chuckpie Posted January 30, 2008 Author Member Report Share Posted January 30, 2008 The problem is that I don't know initial units. If I have 1 unit of coordinale, how many meters is it? Andrew; You have a great point. Sometimes we tend to forget ours is not the only country in this world (sorry). I also realize the metric system is the most widely used system except in the US. Anyway the only reason for the request is that it would allow me to match Lightwave which I have set to English (US) system. Instead of providing all the calculations the best way is if I sent you the link to the conversion software(free) I use and see if that would solve the problem. http://joshmadison.com/software/convert/download.php Thanks, Chuck Quote Link to comment Share on other sites More sharing options...
Advanced Member jaf Posted January 30, 2008 Advanced Member Report Share Posted January 30, 2008 Maybe the solution is to add a couple "custom" scale boxes below the existing ones and make the scale values persistent (the values will stay the same each time 3D Brush is loaded, until the user changes them.) I'm assuming the length value is always meters. If you enter the value 3.28084 in the scale box, the resulting length value is in feet. Make a 1 foot cube in LW and import it into 3D Brush (unsmoothed). With the scale set to 3.28084, the length across each face will be real close to 1 (foot). If you put 39.37 (3.28084 x 12) in the scale you would get a measurement of "real close to 12 (inches). Here's a possible way to implement some custom scales. This leaves it to the user to enter their scaling value(s) and labels. Arrow 1 is where the user's scaling value is set. Arrow 2 points to the label the user enters. Arrow 3 will be the result of the Scale value (arrow 1) x Measure value (arrow 4). So if the value where arrow 4 points is 1, the value where arrow 3 points would be 3.28084 (feet in 1 meter). Let the user be responsible for the scales. It would be easy for us to make a conversion chart up for the help files. Anyway, this may be one way to implement a conversion/measure tool. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted January 31, 2008 Report Share Posted January 31, 2008 Thanks for ideas! Done. Quote Link to comment Share on other sites More sharing options...
