Andrew Shpagin Posted January 31, 2008 Share Posted January 31, 2008 I have add the new curve profile - arrow. Also you can mark some points like sharp. How it looks? It is better to see then to read. Coming soon in 2.05! Quote Link to comment Share on other sites More sharing options...
Advanced Member wailingmonkey Posted January 31, 2008 Advanced Member Share Posted January 31, 2008 Interesting! An immediate thought came to mind...what about a double-headed splines (start and final point would have the arrowhead in opposite directions, in this case) option? Maybe a checkbox for 'no arrowhead', 'arrowhead at start', 'arrowhead at last', 'arrowhead start/last'... This would offer an easy way to make banner-like shapes for signs, intricate scrollwork on armor, etc. I know, I know...always asking for more. Just curious also how you're doing it. Stamp the alpha first, then drag the profile the length of the spline? Anyhow, glad to see it looks like you're having some fun with this. cheers. wailingmonkey *edit* After thinking about this some more, I wondered if you had considered putting more power/control on the actual spline point. So a user could have a panel of options (with the default being the original 'zero' behavior that's currently in use) that would change how that spline point behaved... - width -depth -corner/no-corner (for 90-degree spline lines...or 'sharp' corners) -specific pen/alpha for the point -whether the point acts like a 'stamp' or if it's just another spline point along the path line profile -whether the profile should be merged from last pen/alpha to new different pen/alpha with a percentage of where the merge/blend happens (or just kept the previous profile line blended into the new pen/alpha 'stamp') -if it acts like a 'stamp' then adding the ability to give the stamp directional control (rotation option) ...... Also, this is another good example of how using the Shift-Screen-constrain key combo (horizontal, vertical, or 45-degree constraint based on the screen) could come in handy when laying down the spline points. Quote Link to comment Share on other sites More sharing options...
Advanced Member yukon_28 Posted February 1, 2008 Advanced Member Share Posted February 1, 2008 Good idea, i'd like to see arrows in 3db. Also i agree with After thinking about this some more, I wondered if you had considered putting morepower/control on the actual spline point. spline tools in 3db are unique, so its a good point to make them stronger. Quote Link to comment Share on other sites More sharing options...
