Member RobH2 Posted February 18, 2011 Member Report Share Posted February 18, 2011 I am retopoligizing a hand with a latex glove on it and then need to render out an image that gives the wireframe thickness, like a screen mesh. I have no problem retopoligizing meshes but how can I make the mesh or model 'uniform' with the exact same mesh grid spacing over the whole mesh? Can 3D-Coat do something like this. I need a mesh that is very evenly spaced so it looks very nice and clean when the wireframe is rendered. Here is what it might look like but imagine it a hand instead of a plane. Example Mesh Quote Link to comment Share on other sites More sharing options...
Member Adamek Posted February 18, 2011 Member Report Share Posted February 18, 2011 Hm. Export retopo mesh to any other 3D package. In 3DS MAX in material editor there is an option o render mesh as wireframe. You can adjust wire thickness and color. As for clean mesh in max there is modifier TurboSmooth. It bends all of the wire so they render as curves connected in a vertex point. Quote Link to comment Share on other sites More sharing options...
Psmith Posted February 18, 2011 Report Share Posted February 18, 2011 Using "AUTOPO" - leaving all settings at their default - and not adding any density shading or guides - will often produce a very regularly spaced, quad mesh - even on things like a glove. Give it a try. If you need a coarser or a denser mesh - the only setting you should change would be the "Approximate poly count" number. Greg Smith Quote Link to comment Share on other sites More sharing options...
Advanced Member wailingmonkey Posted February 18, 2011 Advanced Member Report Share Posted February 18, 2011 another option might be to do a very basic 'manual' retopo (super-lowpoly) and just keep subdividing to the level you want...so you're basically setting up the vertices you want the edgeflow to move around (like 4 sides on all fingers, even-ish spacing across the top/bottom of the palm, etc.). Each sub-d will snap the new 'cage' to your underlying geo. image for clarity (used 'Brush' tool in retopo room with shift key to smooth): Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted February 19, 2011 Report Share Posted February 19, 2011 Hm. Export retopo mesh to any other 3D package. In 3DS MAX in material editor there is an option o render mesh as wireframe. You can adjust wire thickness and color. As for clean mesh in max there is modifier TurboSmooth. It bends all of the wire so they render as curves connected in a vertex point. Yes LightWave also has this option, in Layout just select the object and hit P for Properties, under the Edges tab you'll find wireframe options. If you need it to be a sub-d object check out the plugin called asPolygon Coloring. Quote Link to comment Share on other sites More sharing options...
Member RobH2 Posted February 20, 2011 Author Member Report Share Posted February 20, 2011 Hey guys thanks for all the great suggestions. I'll try them all except I can't do the Lightwave one as I use 3DMax. I think from the suggestions you gave me I can come up with a nice mesh with regular spacing. Thanks again... Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 20, 2011 Reputable Contributor Report Share Posted February 20, 2011 Hey guys thanks for all the great suggestions. I'll try them all except I can't do the Lightwave one as I use 3DMax. I think from the suggestions you gave me I can come up with a nice mesh with regular spacing. Thanks again... If not, the Graphite Modeling tools in Max has a feature in the "Edge Tools" section to even out selected edges/edgeloops. The button is aptly named "Space"...try it on one portion of the body at a time, and it should come out fine. Quote Link to comment Share on other sites More sharing options...
