Advanced Member jamie Posted April 14, 2011 Advanced Member Report Share Posted April 14, 2011 Hi, Our user's home directories are on the server, which means my 3dcoat prefs/textures/tools get saved over the network. This slows the program down to an unusable level. How do I set the directory 3dcoat uses to store this information? I see there are config.txt and link.txt files, but I have no idea what they should contain. Thanks, Jamie Macdougall jamiem@image-engine.com 3d Generalist Image Engine VFX Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted April 20, 2011 Report Share Posted April 20, 2011 Please look description at the end of document : (Separating changed data from installed files to share data between users) http://www.3d-coat.com/files/floating.pdf Quote Link to comment Share on other sites More sharing options...
Advanced Member Spiraloid Posted April 20, 2011 Advanced Member Report Share Posted April 20, 2011 Please look description at the end of document : (Separating changed data from installed files to share data between users) http://www.3d-coat.com/files/floating.pdf along these lines I wish the shaders foreach vox layer were saved in the scene. when I move my .3b files between machines with different shader directories. the vox layers lose all the colors I setup on each layer. Quote Link to comment Share on other sites More sharing options...
Advanced Member jamie Posted April 23, 2011 Author Advanced Member Report Share Posted April 23, 2011 Thank you Andrew for helping with this. It's Easter Friday here but I'll try it out at work first thing tomorrow. Quote Link to comment Share on other sites More sharing options...
Advanced Member jamie Posted April 24, 2011 Author Advanced Member Report Share Posted April 24, 2011 This is very helpful. Since I've set the COAT_FILES_PATH variable pointing to a local disk I haven't noticed any of the stroke delays that have been plaguing me for last couple of weeks! Brilliant! Quote Link to comment Share on other sites More sharing options...
