3D Coat Forums
Wasili
Retopo objects and surface materials
Hello! I had this problem http://take.ms/j0wXc
so I did some polygons in addition to the lack of symmetry. As a result, here's what I got when exporting and then importing the model  http://take.ms/7VvDl
Why is there a single mesh in the retopo objects, and two separate meshes in the surface materials?
HI
Its virtual mirror Mode = off ?
On 7/17/2017 at 6:43 PM, Tony Nemo said:
Whether to use it or not depends on your preference. If you prefer symmetry on and virtual mirror mode selected, you will do all your work on one side and will eventually need to 'app;y' the mirrored half. With this mode deselected and Symmetry 'On',  you can make edits on both sides where with virtual on you would only work one side.
8 minutes ago, Carlosan said:
"with virtual off you would only work one side".:rolleyes:
17 minutes ago, Carlosan said:
I turned off the virtual simmetry and got this result  http://take.ms/g9FJH
Those polygons that I add are some kind of foreign. When importing into the surfice materials, they then go to a separate mesh
Yes, it works on the one side. The symmetry was not applied correctly and I exported this mesh and then added more polygons, but they become some kind of foreign material like this  http://take.ms/g9FJH
How many UVset do you have ?
  Thank you! You have helped me a lot, now I understand what was the matter - they were other UV - sets.
Can I ask more about this?    http://take.ms/KpaM2   This is a bug?
1 - Virtual Mirror mode = off
2 - Symmetry off
3 - Make retopo of right half side of the model
4 - Once finished, turn Symmetry on
5 - Then perform symmetrical copy of the layer.
- or
1 - Virtual Mirror mode = on
2 - Symmetry on
4 - Once finished, turn Virtual mirror mode off
5 - Then perform symmetrical copy of the layer.s
2 - Symmetry off
- or
2 - Symmetry on
   Thank you! I exported the retopo to a new scene and there mirrored it. It must have been a glitch. Did you encounter such a problem with the coordinates when importing? -   http://take.ms/ZiVmY
Is your Sculpt layer In Global Space ?
RMB over the layer > To Global Space command.
11 hours ago, Carlosan said:
Является ли ваш слой Sculpt в глобальном пространстве?
RMB над слоем> Команда Global Space.
Coordinates are saved only in sculpture mode? Here's how I get   http://take.ms/yGQUt
