Voxel import obj with multiple objects with each object on seperat voxel layer
  • Please log in to reply
9 replies to this topic
#1 bisenberger
bisenberger
    Novice
  • PipPip
  • 277 posts
  • Gender:Male
Posted 13 February 2012 - 07:10 AM
This would make certain that the multiple objects were imported at the same scale and relative location and allow the individual objects to be edited independantly.
GeoForce GTX 460, Intel Core 2 Quad Q6600, Windows 7 Professional 64-bit.
#2 herve_bis
herve_bis
    Novice
  • PipPip
  • 253 posts
  • Gender:Male
Posted 13 February 2012 - 09:43 AM
+1
#3 AbnRanger
AbnRanger
    Master
  • PipPipPipPipPipPip
  • 6,261 posts
  • Gender:Male
Posted 13 February 2012 - 01:15 PM
Have you tried checking "Merge to Separate Volumes" in the Merge tool options?
#4 The Candy-floss Kid
The Candy-floss Kid
    Apprentice
  • PipPipPip
  • 608 posts
  • Gender:Male
Posted 13 February 2012 - 01:19 PM
Imported/ merged objects as separate surface object instances is already available
3DCoat imports meshes with groups/polygroups/parts etc as a nested volume but will not export the modified components out as one unified mesh with separate components, each must in turn be separated out from the nested group and exported individually which is a great shame production wise. At least for me that is the case I have had no luck exporting the nested volume.
Ah I see AbRanger has already replied before I'd even posted
To be able to export a nested surface object
+1
#5 AbnRanger
AbnRanger
    Master
  • 6,261 posts
  • Gender:Male
Posted 13 February 2012 - 01:54 PM
Do you mean export directly from the Voxel Room? Haven't tried that, but if you retopo and merge to the Paint Room, thenexport, all objects in the scene get exported as one OBJ file.
  • bisenberger likes this
#6 bisenberger
bisenberger
    Novice
  • PipPip
  • 277 posts
  • Gender:Male
Posted 13 February 2012 - 05:04 PM
Thanks guys. The "Merge to Separate Volumes" worked great.
#7 The Candy-floss Kid
The Candy-floss Kid
    Apprentice
  • PipPipPip
  • 608 posts
  • Gender:Male
Posted 14 February 2012 - 12:11 PM
AbnRanger yes I had attempted to export from the Voxel room after using liveclay to poly reduce on a per layer basis.
#8 AbnRanger
AbnRanger
    Master
  • 6,261 posts
  • Gender:Male
Posted 14 February 2012 - 12:56 PM
For now, you will probably have to right-click each layer and export them as separate files. Then in an external program import them into the scene and do whatever merging/grouping operation you need at that stage.
#9 The Candy-floss Kid
The Candy-floss Kid
    Apprentice
  • PipPipPip
  • 608 posts
  • Gender:Male
Posted 15 February 2012 - 06:04 AM
Thanks AbnRanger , yes for the time being that seems the best bet - export per layer.
#10 Democaliber
Democaliber
    Newbie
  • New Member
  • 3 posts
Posted 04 December 2015 - 04:51 PM
This thread helped me more than anything else. Import as Child being the new 'Separate Volumes' threw me for a loop. I'm wondering...when I change from the Sculpt room to the Retopo room, my mesh looks blown apart versus having my original HP model. Any idea as to what's going on?
http://imgur.com/a/7iHY7
This is the album that has the two shots; the normal looking one has my model in the Sculpt room with the Volume 4 layer turned off...the other is what my model looks like in the Retop room. I'm sure I'm just missing a checkbox/option somewhere. Anyways, help would be greatly appreciated! Cheers!
