Showing results for tags 'Bug'.
  1. Hey guys, It's been a while since I touched 3dcoat and vox extrude used to be an important tool in my workflow but it seems to crash the program whenever I hit apply. Any suggestions on how I can fix it?
  2. I was working on a project that my coworker had started. I was doing some minor repainting and then going to add some smart materials. When I clicked on a leather based Smart Material, it produced the screen below. I double checked, and it crashed on other smart materials are clicked on too. I've opened other projects, and it does not crash. So it is specific to this particular file. Any ideas or help? Let me know if I need to provide more information and I'll do my best.
  3. I installed 3D-Coat demo yesterday, on windows 10 pro creator version. I have strange problems in the layer blending window with floating point numbers that go strange. See the picture, no explanation needed anymore. Only anoying because it can only be fixed by restart of 3dcoat. Running the OpenGL version. Driver 382.05. time to install a new driver. Also the Lock transperancy checkbox is flashing on and off. the numbers not keep stable to.
  4. I have 2 monitoprs. and afterv hint fdrom other forum poster using that with pleasure. Not sure how people can work with 3d-coat on single screen, not much space. But, there's a problem i have with 3d-coat 4.7.24 (DX version with this test, GL have other problems) When i import FBX file with the option "model for per pixel painting" It's moving most of the time windows from 3d-coat i have on the secondairy screen back to my main. I can fix it by "restore this page layout" but if you do that a few times in a row it get a bit Grrr.. |This is what happens. first how i have it. second picture how it looks after i have imported the fbx. Btw. Would be nice if you can move the camera puldown box and everything more to the left side of the main screen.
  5. me = just loaded up 3dcoat to finish texturing this and I'm saw that this has happened! I = can press *6* (lowpoly) to make it go but when I'm = goes into render it it just shows this silliness again! can anyone helps me please? I'm = don't wanna restart him he was a lot of work :/
  6. huggmachine
    Update Islands does not work
    I'm trying to update islands with a new seam but the islands simply will not update. The seams show up in the viewport and UV preview but the seam isn't applied when attempting to update. I want my Teal/Purple islands to use the same UV space but unfortunately applying a new unwrap rather than island update will cause issues. Wat do?
  7. Hello everyone, I am new to 3dcoat and am currently using the demo version. Sculpting is amazing but autoretopo isn't working on all the models, some very simples ones made of spheres don't turn into polymesh spheres, instead I get nothing. Can someone help me?
  8. Hi,I am very new to 3d-coat so I might be wrong but it seems "sphere" function does not work correctly in Mac version of 3D-coat. I tried to change tool settings but had no luck and the function kept working almost same as the "blob" function. Here is the environment: Mac Book Pro early 2013 Geforce GT N650 OS Mac OS 10.1.24 Memory 8GB 3D-coat ver4.7.23 There I see some drawing issues but I can ignore. Maybe because of poor machine power of my mac book. I would like to know if the malfunction such as above has been one of known issues, demo specific problem or so... I own Windows version and trying free demo of Mac version because I am thinking adding Mac license. Working on 3D-coat outside of my house would be fantastic! Gen
  9. Hi, This is not a very serious issue, but rather a small small annoyance: 3D Coat on Steam does not show the time spent using it. For me it always shows "0.0 hrs on record". Others have the same problem too: http://steamcommunity.com/app/100980/discussions/0/648814845633449132/ http://steamcommunity.com/app/100980/discussions/0/360670708787560538/ Thanks!
  10. shotgun
    Flase Color picking
    1 pixel may pick a certain (true) color and the pixel next would sample false (see-through style) Edit > Project through and Backface culling have no effect This happens seemingly randomly, on various imported objects and from both ortho and non-ortho views
  11. Kirill Novozhilov
    Crash in Paint Room
    Hi, i frequently get crashes in both DG and in GL Version. Especially in paint room! Is there a way to fix the crash? Did not find any solution in internet
  12. Testing 3D Coat. Using windoiws 10 64bit creator update. When i select a smart material and then the fill option, i get a dialog. "Filling may take a long time, continue ?" At that point i do not have any mouse pointer as long it's in the 3D coat program or until i close the window with the shortcut key
  13. Kirill Novozhilov
    Crash in Paint Room
  14. I'm painting in 3D Coat and i have everything organized inside groups, whenever I send to photoshop and saved there, the groups get messed up. Already tried everything, I have removed all the groups and created new ones, already changed the name of each layer (with and without "_" ) and each group, this always happens. There is no space in the names, everything works normal until i save in photoshop and return to 3D Coat. The bottom group is added to the top group creating a ladder of groups, one inside the other. I already exported all layers as .psd, opened in photoshop, saved and reimportei in a new file in 3D Coat and the same happens How can I fix this problem? Even if i put all groups inside a main group holding all groups this happens after i save in photoshop EDIT: Also tried with 3D Coat 4.7.23 64-bit. Same problem
  15. I don't know what's going on but for some reason my stroke mode quits rubber banding to show the selection. Is there something I'm doing wrong? Is there a setting I'm accidently toggling? Here's a link showing the issue.
  16. I redoktiruyu projection in your wonderful application (no sarcasm), save and turn into 3D COAT and distortion occurs. Please help fix
  17. Encountered this today during one of countless external editor sessions: The upper image is pre-edit. The one below shows the texture as it came back from PS. There are numerous pixelly distortions (circled in blue), all were created when the texture was sent to PS from 3DC. Solution was re-import theOBJ and reassign the textures, but still... This thread would typically go in the paint mode bugs forum, but that has not been updated for 2 years so... I also made a thread in 'features' forum which I intended to keep udpate but I am unable to reply to my own thread, I guess it was locked? if a mod can chip in here it would be nice
  18. hey, so if i have an object with a lot of overlapped / mirrored uves, 3d coat either takes a loong time to open it or it crashes, is there something i need to tick off , is it trying to calculate something even if i set it to "keep the uv's " ?
  19. Okey so i am making a sword. First I made the blade and then i made the hilt. A fter retopologizing the blade i painted it and everything went fine. But when i tried to paint the hilt i do not get any metalness or roughness. in the submitted picture i painted with the same brush on the hilt and the blade to show that the metalness only affects the blade. Please help me.
  20. This has been a bug since I've owned the program and it's so frequent and not being fixed that I'm starting to think about switching, which is really disappointing. It requires me to completely redo the model. I don't know why it does it, but i just opened a file and the model was corrupt. It also happens while modeling. BUT, I found a workaround, which is really odd. I've uploaded the 3D coat file ("6.b") 1) Problem: The polygons corrupt and become 'jagged' 2) Solution: Resample the model and it doesnt matter what value you resample it. I don't know if this will always fix it but its working for now 6.3b
  21. 1. Create voxel model 2. Switch to paint room 3. Start paint -> then program crush immediately I'm on mac, version 4.5.40.
  22. After a crash, always Bug Report fails to send. I would very much like to be helpful and send them, but I always get red text "Error ocurred while sending Bug report" please, "Occurred" (past tense: occurred; past participle: occurred) I'm running4.5.40 GL64 Win I'm using Windows 7 and latest Google Chrome
  23. videogameronline
    Invisible Polygons?
    So I use 3d coat to help with making skins for the game csgo. (counterstrike global offensive) The problem is on a few obj weapon models there are invisible spots were the gun is just not rendered in 3d coat. This in turn translates to being nothing (checkered background) in photoshop when I send to edit in external editor. Also when I look at this same area of the model from another angle it displays correctly. It seems one side of this polygon is invisible while the other side works as it should. Ultimately it turns into a white triangle on the finished product. Any ideas on what's happening here? I'm using the steam version of 3dcoat with windows 10, Nvidia 970 graphics card, 3770k cpu. The p
  24. SebastianLeon
    Paint Room Layer Issue
    Hi guys, Does anyone know why 3d-coat is giving me the wrong layers inside the Paint room? I exported my Obj and then imported it into the Paint room. I've tried restarting the program and selecting other meshes but nothing seems to solve this issue. It's very frustrating not being able to handle my material layers I hope someone knows the answer
  25. There is a bug affecting every model I create. It's really inconsistent. Sometimes when I undo or smooth, or turn symmetry off, it corrupts my mesh and is irreparable. It basically causes he mesh to have zero width on some part of it. I can't even undo to reverse the changes and hope to god that I have saved a recent backup. See attachment to view what happens. Notice the top part of the model's head that looks like its see through and pixelated almost.
