Showing results for tags 'help'.
Is there a fast way to select a Paint Object from the 3D view? I want to single out a spesific object to paint on it, but finding it in the Paint Objects pannel takes way too long. I know you can hit H and it will automatically select a voxel layer but that doesn't work with paint objects. Is there a way to convert paint objects to voxel layers Another possible workaround would be if I can somehow see the Paint Object's name when I hover over it in the 3D view. Even naming the layers won't help btw because there are way too many of them.
sculpt How do I make the extrude brush paint at a straight line?
CMTK posted a topic in General 3DCoat
I want to make the orange screens in the reference, but I can't figure out how to make the extrude brush paint at a straight line. Any way I can do that? -
Now that I figured out how to do the seven shapes on the table, I need to boolean out some of the parts off the edge of the upper level as seen on the reference. Any good way to do this?
I'm trying to sculpt the highlighted mesh as seen in the pictures above. I used the blob tool with radial symmetry, but the result gives a mesh that is offsetted on the X axis which can't be fixed no matter what I try. Is there a better way to do it?
sculpt Why can't I place a primitive if the top radius is bigger?
It used to work fine in .49, but after updating to .53, it do esn't work anymore video0.mov -
retopo How do I stop my tool from only snapping onto vertices?
video0 (2).mov I want to tool to snap to edges as well as vertices, but I don't know how. -
I’ve been asking everyone about this mystery and nobody has been able to explain how this works. I asked multiple people to try the same operation and all they got were 31 points on the bottom of the mesh placed in the same exact way no matter where on the mesh they clicked. As far as I know, the tutorial guy was the only one to have successfully done the operation and not even he has any idea what is going on. We checked everything that could go wrong and NOTHING worked! Please help. FullSizeRender.mov
So I was able to get the radial symmetry working on the tool by turning of Virtual Mirror Mode, sort of. Now the tool makes multiple points, but they are always placed at the bottom of the mesh in a very specific way no matter which side of the mesh I click on. Is there a fix for this? https://cdn.discordapp.com/attachments/680168650791321774/728034794939613194/video0.mov
According to a tutorial (https://youtu.be/cNAMye3-jSE?t=283), the points/faces tool is supposed to put multiple points when radial symmetry is turned on. However, it's not the case for me (https://cdn.discordapp.com/attachments/541652288276660254/726601367560519720/video0.mov). When I use the tool with the same symmetry settings, it completely ignores the symmetry. I tried everything, but nothing fixed it. Is there a fix? (File: http://www.mediafire.com/file/2qve76c78607mek/first_project.3b/file)
I've been practicing making "skins" for a video game I play just for the sake of learning. I could make a few but then I ran into an issue with the program. Whenever I go to edit projections in my ext. editor (Photoshop) it messes up the lighting completely and ruins the picture I add. (For example the one I've attached to this message.) I didn't have this problem yesterday, it occurred today, just a few hours before. I reset all my settings back to default, yet it still didn't help in any way. I apologize if this was the wrong place to message for help about this, didn't find a place in your forums for that. The categories were irrelevant, and then there was one for "SOS only urgent matters", an since this isn't SOS urgent, I can't post there. If there's a solution to this problem, I would be really thankful. Have a nice week! Santeri K
Hi, I want to sculpt a pillar four or more side the same patterns. When I open Ignore Back Faces, It's kind of weird. When I close Ignore Back Faces, I got the thick what I want, but only three sides of the pillar. How should I do it? Could you help? Thanks & Best Regards, K.
Hi, I'm wondering if anyone knows how to move a painted character in Substance painter back into 3Dcoat. I'm new to all of this so quite confused at all how this works.
- urgent
- uniproject
Hi, me again. I build a cockpit, but when I assign materials, I find I need to split the model. I want to assign a white place with glass, other with metal. Then I don't know how could I do it in 3dcoat, could you help? Or maybe I should use masks in ZB? Thanks & Best Regards, K.
I don't see a "non-urgent help" board, so I hope it's okay if I post this here. I can't find the Alpha Panel. By everything I've seen, it should be under Windows>Panels. Attaching screenshots. Thanks so much for the help, new user obviously.
Hi, Me again. When I try to mirror my object from left to the right, it's just disappeared. I don't know why, could you help?
Hello, I made a group of layers and I want to make a copy then change a little. Could I ask how to copy a group of layers? Symmetry a group? or Must I merge everything? Thanks & Best Regards.
Hi, Sorry, I am again. When I use symmetry to mirror, sometimes, mirror to nothing. Could someone tell me why? Thanks & Best Regards.
Hi, I am a new rookie in 3dcoat. I have a problem when I use the 2d paint tool. I want to paint some patterns on the bottle, but I can't use the 2d paint tool well. Whenever I painted on the first layer, it would automatically change to the second layer paint. Could you help, please? Thanks & Best Regards.
Hi guys, Upgraded to the professional version a few hours ago and I'm trying to sketch on the Paint Tab. However, I'm unable to actually paint- as my cursor won't change into the brush and I keep getting "Please Choose an Option" down at the bottom. I'm basically just trying to do this. I'm not totally new to 3dcoat, but I'm having trouble figuring out why I can't paint! Any help would be greatly appreciated, thanks!
Hi, I can' run app (it crashes immediately). Can someone hep? Thank you! masOS Catalina 10.15.3 ---- Process: 3DCoat [18361] Path: /private/var/folders/*/3DCoat.app/Contents/MacOS/3DCoat Identifier: com.Pilgway.-D-Coat Version: 4.9.03 (1) Code Type: X86-64 (Native) Parent Process: ??? [1] Responsible: 3DCoat [18361] User ID: 501 Date/Time: 2020-03-15 22:23:46.943 +0200 OS Version: Mac OS X 10.15.3 (19D76) Report Version: 12 Anonymous UUID: AB463035-A1D2-982D-6E57-56FF2E83D5F1 Sleep/Wake UUID: 94429528-994F-416B-9FBD-D087E31BCA59 Time Awake Since Boot: 2800000 seconds Time Since Wake: 450000 seconds System Integrity Protection: enabled Notes: Translocated Process Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_ACCESS (SIGSEGV) Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000010 Exception Note: EXC_CORPSE_NOTIFY Termination Signal: Segmentation fault: 11 Termination Reason: Namespace SIGNAL, Code 0xb Terminating Process: exc handler [18361] VM Regions Near 0x10: --> __TEXT 000000010a5e5000-000000010b975000 [ 19.6M] r-x/rwx SM=COW /var/folders/*/3DCoat.app/Contents/MacOS/3DCoat Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 com.Pilgway.-D-Coat 0x000000010ae0e5c2 GeneralPen::RenderMtlPreview(Rct*) + 1746 1 com.Pilgway.-D-Coat 0x000000010abe2e5b MainRender() + 686 2 com.Pilgway.-D-Coat 0x000000010abe391a MainCycle() + 85 3 com.Pilgway.-D-Coat 0x000000010a719e3e comms::cMain_OnRender(comms::cRect const&) + 386 4 com.Pilgway.-D-Coat 0x000000010b19b2f8 cMacMain_OneIterationOfMessageLoop() + 2430 5 com.Pilgway.-D-Coat 0x000000010b19e3ed main + 4103 6 com.Pilgway.-D-Coat 0x000000010a5eb4b4 start + 52 Thread 1: 0 libsystem_pthread.dylib 0x00007fff63a1f818 start_wqthread + 0 Thread 2: 0 libsystem_pthread.dylib 0x00007fff63a1f818 start_wqthread + 0 Thread 3: 0 libsystem_pthread.dylib 0x00007fff63a1f818 start_wqthread + 0 Thread 4: 0 libsystem_pthread.dylib 0x00007fff63a1f818 start_wqthread + 0 Thread 5: 0 libsystem_kernel.dylib 0x00007fff63962bba __semwait_signal + 10 1 libsystem_c.dylib 0x00007fff638e60fa nanosleep + 196 2 libsystem_c.dylib 0x00007fff638e5ff4 usleep + 53 3 com.Pilgway.-D-Coat 0x000000010b31ef6e comms::SavingThread(void*) + 33 4 libsystem_pthread.dylib 0x00007fff63a23e65 _pthread_start + 148 5 libsystem_pthread.dylib 0x00007fff63a1f83b thread_start + 15 Thread 6: 0 libsystem_pthread.dylib 0x00007fff63a1f818 start_wqthread + 0 Thread 7: 0 libsystem_pthread.dylib 0x00007fff63a1f818 start_wqthread + 0 Thread 8: 0 libsystem_pthread.dylib 0x00007fff63a1f818 start_wqthread + 0 Thread 9: 0 libsystem_kernel.dylib 0x00007fff63962bba __semwait_signal + 10 1 libsystem_c.dylib 0x00007fff638e60fa nanosleep + 196 2 libsystem_c.dylib 0x00007fff638e5ff4 usleep + 53 3 com.Pilgway.-D-Coat 0x000000010b48c6b1 FileWaitThread(void*) + 43 4 libsystem_pthread.dylib 0x00007fff63a23e65 _pthread_start + 148 5 libsystem_pthread.dylib 0x00007fff63a1f83b thread_start + 15 Thread 10: 0 libsystem_kernel.dylib 0x00007fff639637de __connect + 10 1 com.Pilgway.-D-Coat 0x000000010a668592 HttpThread(void*) + 181 2 libsystem_pthread.dylib 0x00007fff63a23e65 _pthread_start + 148 3 libsystem_pthread.dylib 0x00007fff63a1f83b thread_start + 15 Thread 11: 0 libsystem_kernel.dylib 0x00007fff63962bba __semwait_signal + 10 1 libsystem_c.dylib 0x00007fff638e60fa nanosleep + 196 2 libsystem_c.dylib 0x00007fff638e5ff4 usleep + 53 3 com.Pilgway.-D-Coat 0x000000010b2889ec CheckFileThread(void*) + 127 4 libsystem_pthread.dylib 0x00007fff63a23e65 _pthread_start + 148 5 libsystem_pthread.dylib 0x00007fff63a1f83b thread_start + 15 Thread 0 crashed with X86 Thread State (64-bit): rax: 0xfffffffffffffffd rbx: 0x0000000000000000 rcx: 0x0000000000000000 rdx: 0x0000000000000000 rdi: 0x0000000000000000 rsi: 0x0000000000000000 rbp: 0x00007ffee561a680 rsp: 0x00007ffee561a4f0 r8: 0x0000000000000000 r9: 0x00007ffee561a410 r10: 0x0000000000000002 r11: 0xffffffa4f320cc00 r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x000000010bdc06d8 r15: 0x0000000000000000 rip: 0x000000010ae0e5c2 rfl: 0x0000000000010246 cr2: 0x0000000000000010 Logical CPU: 4 Error Code: 0x00000004 (no mapping for user data write) Trap Number: 14 Binary Images: 0x10a5e5000 - 0x10b974fff +com.Pilgway.-D-Coat (4.9.03 - 1) <0B38955E-B5EB-393B-9EFD-11EF3DCC147B> /var/folders/*/3DCoat.app/Contents/MacOS/3DCoat 0x10c944000 - 0x10ed96ff7 +libmkl_intel_thread.dylib (0) <201F62FA-8F14-3936-86D9-EC07E76C13C2> /var/folders/*/3DCoat.app/Contents/MacOS/libmkl_intel_thread.dylib 0x10f62c000 - 0x10f75efc7 +libiomp5.dylib (0) <C78254F3-967C-3ED2-A577-E6670C43E567> /var/folders/*/3DCoat.app/Contents/MacOS/libiomp5.dylib 0x10f7db000 - 0x113542f07 +libmkl_core.dylib (0) <D9CE21EF-4A9D-36A6-A38A-1264B6EC2F09> /var/folders/*/3DCoat.app/Contents/MacOS/libmkl_core.dylib 0x1139f2000 - 0x114cc5fef +libmkl_intel_lp64.dylib (0) <3E21E8A5-70C9-36CD-8609-8FDF5571F937> /var/folders/*/3DCoat.app/Contents/MacOS/libmkl_intel_lp64.dylib 0x114f27000 - 0x11559cff7 +libfbxsdk.dylib (0) <1BD2C958-D0B8-3F5B-BC26-8CA65E4A23C0> /var/folders/*/3DCoat.app/Contents/MacOS/libfbxsdk.dylib 0x1157cf000 - 0x1157fdff7 +libtbb.dylib (0) <99F780E9-29FC-C2F8-4E55-1CE6B6EECFEF> /var/folders/*/3DCoat.app/Contents/MacOS/libtbb.dylib 0x11581a000 - 0x11582cff7 +libtbbmalloc.dylib (0) <1AB33A35-CFF9-36CE-CF73-3D8DBFB1E4E4> /var/folders/*/3DCoat.app/Contents/MacOS/libtbbmalloc.dylib 0x11a6b0000 - 0x11a740cb7 dyld (733.8) <EBC07CB6-870A-3A8E-B48A-67F62EA161F3> /usr/lib/dyld 0x11c619000 - 0x11c61c047 libobjc-trampolines.dylib (781.2) <D4168201-48BA-3B42-A6EF-4341FF583962> /usr/lib/libobjc-trampolines.dylib 0x7fff239f1000 - 0x7fff23f02fff com.apple.driver.AppleIntelHD5000GraphicsGLDriver (14.4.23 - 14.0.4) <67BD6396-F637-3897-86D5-EDF17EE5FAA4> /System/Library/Extensions/AppleIntelHD5000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsGLDriver 0x7fff23f03000 - 0x7fff23f96ffb com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (14.4.23 - 14.0.4) <391E8EF8-C60E-38DB-A798-0757263DB227> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver 0x7fff26911000 - 0x7fff27222fff com.apple.GeForceGLDriver (14.0.31 - 14.0.0) <EB8FB99E-BD38-37B2-A57B-095C9BA21E1B> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver 0x7fff27223000 - 0x7fff278fbff7 libclh.dylib (14.0.31) <8D53418F-999D-382C-A2A1-92EB6CD671D8> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib 0x7fff278fc000 - 0x7fff27ab2ff2 com.apple.GeForceMTLDriver (14.0.31 - 14.0.0) <76883534-CB9B-38FE-B561-9F4012192560> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver 0x7fff27ab3000 - 0x7fff27ab7ffb com.apple.agl (3.3.3 - AGL-3.3.3) <93797B81-445E-3D1B-9C0D-004A4E398F99> /System/Library/Frameworks/AGL.framework/Versions/A/AGL 0x7fff27e9e000 - 0x7fff27e9efff com.apple.Accelerate (1.11 - Accelerate 1.11) <EEBE6680-1AAB-3192-AA7C-450537B07F27> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff27e9f000 - 0x7fff27eb5fff libCGInterfaces.dylib (524.2) <AF390BF7-8AF1-370D-ACC6-118889FA9ADB> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib 0x7fff27eb6000 - 0x7fff28521fef com.apple.vImage (8.1 - 524.2) <33B60C65-1E08-3490-ADC7-6C75AA3EA022> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff28522000 - 0x7fff2878bfff libBLAS.dylib (1303.60.1) <0FE82DB0-0E71-300A-BF0B-70BF3478FE79> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fff2878c000 - 0x7fff28a7bff7 libBNNS.dylib (144.40.3) <86C8FBB0-19D3-355B-99A3-6B094BB98C06> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib 0x7fff28a7d000 - 0x7fff28e22fff libLAPACK.dylib (1303.60.1) <DCC36295-FF39-35A1-8DF1-1E8A714E2265> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fff28e23000 - 0x7fff28e38ff8 libLinearAlgebra.dylib (1303.60.1) <0E47C269-832E-3B55-A6B6-855648BD206E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib 0x7fff28e39000 - 0x7fff28e3eff3 libQuadrature.dylib (7) <E0534024-B7E7-3382-830C-71E7BD9D3DE4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib 0x7fff28e3f000 - 0x7fff28eaffff libSparse.dylib (103) <533DFAE8-8458-31F4-8AE2-B73C3869CED2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib 0x7fff28eb0000 - 0x7fff28ec2fef libSparseBLAS.dylib (1303.60.1) <7CECC6DF-B4A8-38A7-B4E9-0CDDC6EA2510> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib 0x7fff28ec3000 - 0x7fff2909cffb libvDSP.dylib (735.40.1) <BD49856D-39CE-397F-A069-63B2F0D79529> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff2909d000 - 0x7fff29158fd7 libvMisc.dylib (735.40.1) <F3C565E5-8571-3E16-BC22-7687D1A756BD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff29159000 - 0x7fff29159fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A8B35A80-7217-38B1-8A20-E8B4F73124F0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff2915a000 - 0x7fff291b9ffc com.apple.Accounts (113 - 113) <C160B461-1DCD-3936-B8DE-72DD9B6473E1> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts 0x7fff292ff000 - 0x7fff2a0bafff com.apple.AppKit (6.9 - 1894.30.142) <5A1752C0-67F4-3EDF-97DA-81AB42824B7B> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff2a10a000 - 0x7fff2a10afff com.apple.ApplicationServices (48 - 50) <C1A1ED89-4F27-30E4-B53B-34062E971294> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fff2a10b000 - 0x7fff2a176fff com.apple.ApplicationServices.ATS (377 - 493.0.2.1) <99B0135E-8EB3-307E-86E3-04818B690B1A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff2a20f000 - 0x7fff2a24dff8 libFontRegistry.dylib (274.0.2.3) <E20402BC-8E91-359D-B724-BEAA24B75A92> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x7fff2a2a8000 - 0x7fff2a2d7ff7 com.apple.ATSUI (1.0 - 1) <7956D5E1-879C-3A3F-990F-96B57EC0BFD3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATSUI.framework/Versions/A/ATSUI 0x7fff2a2d8000 - 0x7fff2a2dcff3 com.apple.ColorSyncLegacy (4.13.0 - 1) <0805CEBA-9129-3EBC-85A5-32155C2F3D83> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSyncLegacy.framework/Versions/A/ColorSyncLegacy 0x7fff2a377000 - 0x7fff2a3cdff2 com.apple.HIServices (1.22 - 674.1) <A65AE150-AB05-374A-8BC1-C35026566E8D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff2a3ce000 - 0x7fff2a3dcfff com.apple.LangAnalysis (1.7.0 - 1.7.0) <3D4B4F59-6A83-302E-A460-5B903E9756EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fff2a3dd000 - 0x7fff2a422ff2 com.apple.print.framework.PrintCore (15 - 516) <1F202B29-4770-3D69-85D0-2B3F6982C45A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff2a423000 - 0x7fff2a42dfff com.apple.QD (4.0 - 413) <E50C4B4E-F827-31A3-BACF-4ACEBF527F96> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fff2a42e000 - 0x7fff2a43bff0 com.apple.speech.synthesis.framework (9.0.24 - 9.0.24) <4A1B8245-3735-361B-A456-FCE540D78707> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff2a43c000 - 0x7fff2a51cffa com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <7B308BA7-F08A-3E70-A494-F03A688AAA42> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff2a51e000 - 0x7fff2a51efff com.apple.audio.units.AudioUnit (1.14 - 1.14) <C3937FFF-1BCA-3A4F-B718-7D6CB4903907> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x7fff2a894000 - 0x7fff2ac20ff6 com.apple.CFNetwork (1121.1.2 - 1121.1.2) <4E539AC8-A995-3BA8-AAD6-31D97DAE734B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff2ac9b000 - 0x7fff2ac9bfff com.apple.Carbon (160 - 162) <916D6D9E-3FE9-355C-913B-B44CAF35146D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x7fff2ac9c000 - 0x7fff2ac9fffb com.apple.CommonPanels (1.2.6 - 101) <FB59B3A1-2FDC-34B4-A639-981135C97908> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x7fff2aca0000 - 0x7fff2af94ffb com.apple.HIToolbox (2.1.1 - 994) <03BF3899-5DD5-3C1F-9DC6-B4C71CD656B6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff2af95000 - 0x7fff2af98ff3 com.apple.help (1.3.8 - 68) <AF302261-AD99-3AD0-A684-CC24C87B6CED> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x7fff2af99000 - 0x7fff2af9eff7 com.apple.ImageCapture (9.0 - 1600.27.1) <1EFEBF06-C0DD-337E-805E-955A3A462395> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x7fff2af9f000 - 0x7fff2af9ffff com.apple.ink.framework (10.15 - 227) <E967D357-AF2E-338E-864D-CD94E87F6ECE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x7fff2afa0000 - 0x7fff2afbaff2 com.apple.openscripting (1.7 - 185.1) <EAE41338-2712-3774-944C-C946312EA562> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x7fff2afdb000 - 0x7fff2afdbfff com.apple.print.framework.Print (15 - 271) <26144B7F-F5C4-311D-A602-D014F0D4434D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x7fff2afdc000 - 0x7fff2afdeff7 com.apple.securityhi (9.0 - 55008) <E4E32973-55AB-38A9-A57D-50BCDF860646> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x7fff2afdf000 - 0x7fff2afe5ff7 com.apple.speech.recognition.framework (6.0.3 - 6.0.3) <2A1ECC85-580E-3508-BA1B-93222EE431A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x7fff2b18e000 - 0x7fff2b379ff7 com.apple.ColorSync (4.13.0 - 3394.3) <61F27F92-1158-36A0-90D0-911A590F2904> /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fff2b669000 - 0x7fff2bb78ffa com.apple.audio.CoreAudio (5.0 - 5.0) <C1EE25DD-6880-3FFB-8C7D-4CBC10B41BD2> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff2bbcb000 - 0x7fff2bc02ff0 com.apple.CoreBluetooth (1.0 - 1) <D1C334E4-E8C8-3FC4-B203-0555BA8C4932> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth 0x7fff2bc03000 - 0x7fff2bfe5ffe com.apple.CoreData (120 - 977.1) <59E37E60-C008-3FE0-BA4B-CF344BF72B70> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff2bfe6000 - 0x7fff2c0f6ffe com.apple.CoreDisplay (1.0 - 186.3.12) <4E34C576-C833-3E09-870A-13F4860337F5> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay 0x7fff2c0f7000 - 0x7fff2c577fe7 com.apple.CoreFoundation (6.9 - 1674.114) <5810CC45-FB5D-3A78-861F-7BE03F9B2FDD> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff2c579000 - 0x7fff2cbf2ff0 com.apple.CoreGraphics (2.0 - 1348.16) <48655F49-3617-33E6-B023-C2E031778FBF> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fff2cc00000 - 0x7fff2cf5dff5 com.apple.CoreImage (15.0.0 - 920.9) <65109A99-EE48-3228-B73A-33044833A600> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x7fff2d4e7000 - 0x7fff2d4e7fff com.apple.CoreServices (1069.11 - 1069.11) <3BBDA17B-6F86-35F4-B785-AFA2A14B6F51> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff2d4e8000 - 0x7fff2d56dfff com.apple.AE (838 - 838) <877C7270-575A-3D5F-B768-4724037F025D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff2d56e000 - 0x7fff2d84fff7 com.apple.CoreServices.CarbonCore (1217 - 1217) <DDC45E79-973C-3FB0-92EC-392A654179F5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff2d850000 - 0x7fff2d89dff5 com.apple.DictionaryServices (1.2 - 323.3.1) <A21D442C-E7B7-3A6C-BEEC-44B323AF9CB2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff2d89e000 - 0x7fff2d8a6fff com.apple.CoreServices.FSEvents (1268.60.1 - 1268.60.1) <8C772593-A2BA-33A7-BB43-49B9FCDD37CE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents 0x7fff2d8a7000 - 0x7fff2dae0ff0 com.apple.LaunchServices (1069.11 - 1069.11) <7189EED9-9252-3030-AB32-6704AD9AEBAE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff2dae1000 - 0x7fff2db79ff9 com.apple.Metadata (10.7.0 - 2075.7) <AECD1E1F-1C1B-3C42-9ACD-596980F145C2> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff2db7a000 - 0x7fff2dba7ff7 com.apple.CoreServices.OSServices (1069.11 - 1069.11) <67A2F664-DCA1-3FD6-B88E-CF020EA8C59D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff2dba8000 - 0x7fff2dc0ffff com.apple.SearchKit (1.4.1 - 1.4.1) <367BBFA7-F18C-34B6-B4C8-A244A125D5E0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fff2dc10000 - 0x7fff2dc34ff5 com.apple.coreservices.SharedFileList (131.4 - 131.4) <EB8F2B1B-B736-373F-B28B-E4E6F33A00C0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList 0x7fff2df5d000 - 0x7fff2e111ffe com.apple.CoreText (643.1.2.3 - 643.1.2.3) <D955D513-DC79-33A9-9E17-C8D86884DED1> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff2e112000 - 0x7fff2e156fff com.apple.CoreVideo (1.8 - 334.0) <1331FE6E-328D-35FF-BC55-5A2231B804A1> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff2e157000 - 0x7fff2e1e4ff9 com.apple.framework.CoreWLAN (13.0 - 1455.3) <B1553A9E-1AC8-30D4-9B90-C7A719DBBF54> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN 0x7fff2e484000 - 0x7fff2e48afff com.apple.DiskArbitration (2.7 - 2.7) <5BE0B036-DEAB-3191-8D44-B489F4D39EE1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fff2e67e000 - 0x7fff2e7a4ff6 com.apple.FileProvider (265.1 - 265.1) <B361EB77-4CD2-3231-B74F-F479FCD2DD23> /System/Library/Frameworks/FileProvider.framework/Versions/A/FileProvider 0x7fff2e7bc000 - 0x7fff2eb84ffc com.apple.Foundation (6.9 - 1674.114) <532BBAE7-F2BA-3779-94E0-BFEDF2D7AB38> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff2ebf1000 - 0x7fff2ec41ff7 com.apple.GSS (4.0 - 2.0) <5873DEB8-F186-3B53-BDFD-4E827B7EFFA2> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fff2ed7d000 - 0x7fff2ee95ff8 com.apple.Bluetooth (7.0.3 - 7.0.3f5) <B860F9C0-A082-386D-BCA7-4B2BC8384301> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth 0x7fff2eefc000 - 0x7fff2ef9fffb com.apple.framework.IOKit (2.0.2 - 1726.80.1) <B63FE840-8E32-3429-A95D-AB466FE62104> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff2efa1000 - 0x7fff2efb1ffc com.apple.IOSurface (269.6 - 269.6) <23D51648-9363-3696-9BF7-18F1B2AF621B> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fff2f027000 - 0x7fff2f184fee com.apple.ImageIO.framework (3.3.0 - 1972.19) <484C67F4-2E4C-38F0-A2A5-A1CBE66558EE> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fff2f185000 - 0x7fff2f188fff libGIF.dylib (1972.19) <2F8329F3-EE31-38AE-841A-D09BF48CAFF1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fff2f189000 - 0x7fff2f243fe7 libJP2.dylib (1972.19) <3A695C63-A86D-364B-BDC9-D83D5078E371> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x7fff2f244000 - 0x7fff2f268fef libJPEG.dylib (1972.19) <4B2284A3-A308-3F54-AC7C-06FF2ED36ED2> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff2f4e6000 - 0x7fff2f500fef libPng.dylib (1972.19) <DEF9EA12-460F-36B7-92BF-E96673E9470E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff2f501000 - 0x7fff2f502fff libRadiance.dylib (1972.19) <11F23339-C944-30BE-AB22-B30D266F8CC0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff2f503000 - 0x7fff2f54cfeb libTIFF.dylib (1972.19) <74C59557-26A7-362A-BAC5-564EE6867F2A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x7fff30971000 - 0x7fff30983ff3 com.apple.Kerberos (3.0 - 1) <DA356370-C1FA-3C23-9D77-5994EC7DC8C0> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff30984000 - 0x7fff30984fff libHeimdalProxy.dylib (77) <CB20F0B8-EDC1-3592-8B2D-6AEF80BE080B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Libraries/libHeimdalProxy.dylib 0x7fff31534000 - 0x7fff315f7ff1 com.apple.Metal (212.2.4 - 212.2.4) <EF882FC9-08E4-36B3-9BAB-3FF5CD70364F> /System/Library/Frameworks/Metal.framework/Versions/A/Metal 0x7fff31614000 - 0x7fff31650ff3 com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) <65A8E0C0-6266-3229-A58D-DA1E40068E25> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/Versions/A/MPSCore 0x7fff31651000 - 0x7fff316d7fe6 com.apple.MetalPerformanceShaders.MPSImage (1.0 - 1) <CA913DB0-C674-3AC6-AAD9-D28B84C58CF1> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/Versions/A/MPSImage 0x7fff316d8000 - 0x7fff316fcff8 com.apple.MetalPerformanceShaders.MPSMatrix (1.0 - 1) <21FB637B-669C-3499-8BF3-1782B1484D52> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/Versions/A/MPSMatrix 0x7fff316fd000 - 0x7fff31712fff com.apple.MetalPerformanceShaders.MPSNDArray (1.0 - 1) <0EE1E81D-0ABE-355D-B33B-5E5365C907C1> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNDArray.framework/Versions/A/MPSNDArray 0x7fff31713000 - 0x7fff31872ff4 com.apple.MetalPerformanceShaders.MPSNeuralNetwork (1.0 - 1) <850F399A-D538-3A36-A0AF-5EB20AA55062> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/Versions/A/MPSNeuralNetwork 0x7fff31873000 - 0x7fff318c1ff7 com.apple.MetalPerformanceShaders.MPSRayIntersector (1.0 - 1) <C71ECDCD-701A-3839-8627-0DF1A8906452> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSRayIntersector.framework/Versions/A/MPSRayIntersector 0x7fff318c2000 - 0x7fff318c3ff5 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <97194F33-650C-31C1-8A5A-56F48E5F5ECB> /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders 0x7fff32809000 - 0x7fff32815ffe com.apple.NetFS (6.0 - 4.0) <0B2088AE-C16D-3FC3-9445-4EDAD2D51686> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff32816000 - 0x7fff32959ff6 com.apple.Network (1.0 - 1) <16D0A17C-1FA8-336C-A082-3AD2A3DB8E3C> /System/Library/Frameworks/Network.framework/Versions/A/Network 0x7fff35379000 - 0x7fff35381fff libcldcpuengine.dylib (2.12.7) <C56327E2-20A5-3B6E-9B77-601E02E6DC4D> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib 0x7fff35382000 - 0x7fff353daff7 com.apple.opencl (3.5 - 3.5) <2B78F795-7131-3AAC-A2FB-FF01CB4A386D> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x7fff353db000 - 0x7fff353f7fff com.apple.CFOpenDirectory (10.15 - 220.40.1) <FF068FF7-C136-3A71-AD1F-B5170A918423> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff353f8000 - 0x7fff35403ff7 com.apple.OpenDirectory (10.15 - 220.40.1) <9448EC8E-8B76-3142-9540-C0752529762A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fff35d5e000 - 0x7fff35d60fff libCVMSPluginSupport.dylib (17.10.22) <87C47A23-D8E9-3AE3-AADF-0DE1FF03905E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fff35d61000 - 0x7fff35d66fff libCoreFSCache.dylib (176.10) <E5C4E721-5BD3-350D-8FD2-12397CD1858D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib 0x7fff35d67000 - 0x7fff35d6bfff libCoreVMClient.dylib (176.10) <35078399-3429-3EF5-AA29-C7E6CDB0F5FB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fff35d6c000 - 0x7fff35d74ff7 libGFXShared.dylib (17.10.22) <2E8AF2C7-2BA8-3385-B7F5-F4E1234B5A8A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff35d75000 - 0x7fff35d7ffff libGL.dylib (17.10.22) <0EDD0D07-1CDD-3E35-8CAB-EDD65862E321> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fff35d80000 - 0x7fff35db5fff libGLImage.dylib (17.10.22) <86F7497C-6178-3E25-8BAD-9882681EAC84> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff35db6000 - 0x7fff35f48ff7 libGLProgrammability.dylib (17.10.22) <A32F3C25-33DE-33E3-BF78-316259A5BA1D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x7fff35f49000 - 0x7fff35f85fff libGLU.dylib (17.10.22) <ECEA64DF-30EC-3709-9EED-C9970BC31DB3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff369b5000 - 0x7fff369c4ff7 com.apple.opengl (17.10.22 - 17.10.22) <9530427D-0AE4-3F7D-B036-73FD32DDAD77> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff369c5000 - 0x7fff36b3eff7 GLEngine (17.10.22) <2436E4A2-A77D-3DD6-879E-2E02B1B43812> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine 0x7fff36b3f000 - 0x7fff36b67fff GLRendererFloat (17.10.22) <EE63BD85-5651-3F19-A0BD-CAE0B4405645> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat 0x7fff3797f000 - 0x7fff37bfeff1 com.apple.QuartzCore (1.11 - 820.6) <5366D2D9-670F-3B9B-A1F2-9C44F7DFC8E8> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x7fff3874e000 - 0x7fff38aa0ffa com.apple.security (7.0 - 59306.80.4) <FA5EBA16-2B2B-3105-8A17-C8624C4B3BB3> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff38aa1000 - 0x7fff38b2aff7 com.apple.securityfoundation (6.0 - 55236.60.1) <0129932D-89E5-3608-B22E-DB5F0B3C3DC4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff38b59000 - 0x7fff38b5dff0 com.apple.xpc.ServiceManagement (1.0 - 1) <2475707B-F909-33C4-AAB7-80DC8D2CB435> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fff398f0000 - 0x7fff3995afff com.apple.SystemConfiguration (1.19 - 1.19) <61B73150-6D87-3E2F-A935-B957425CC992> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff3d6c5000 - 0x7fff3d789fe7 com.apple.APFS (1412.81.1 - 1412.81.1) <7EC14196-E481-35C0-94F0-09E5B81AD3E5> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS 0x7fff3e88a000 - 0x7fff3e88bff1 com.apple.AggregateDictionary (1.0 - 1) <4EA2428D-FFB2-372C-BC1C-821BE221E8D0> /System/Library/PrivateFrameworks/AggregateDictionary.framework/Versions/A/AggregateDictionary 0x7fff3ed9b000 - 0x7fff3edb8ffc com.apple.AppContainer (4.0 - 448.60.2) <A862A822-AA47-35DB-94FE-20B91B7E5F4A> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer 0x7fff3ee0d000 - 0x7fff3ee1bff7 com.apple.AppSandbox (4.0 - 448.60.2) <0F317402-65DC-3D99-91BD-BA3F06B60517> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox 0x7fff3f2aa000 - 0x7fff3f2ceff3 com.apple.framework.Apple80211 (13.0 - 1460.1) <CB83A2CF-78A4-3E94-83C1-845037EB84FF> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211 0x7fff3f404000 - 0x7fff3f413fef com.apple.AppleFSCompression (119 - 1.0) <EEDA4040-1835-39A6-AC13-6CE35560C159> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression 0x7fff3f512000 - 0x7fff3f51dff7 com.apple.AppleIDAuthSupport (1.0 - 1) <CBD0CBCD-C403-37FA-87C8-CCE0D4462452> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport 0x7fff3f55f000 - 0x7fff3f5a7fff com.apple.AppleJPEG (1.0 - 1) <42E71E36-8AFA-300C-8322-B6FE66E68441> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG 0x7fff3f987000 - 0x7fff3f9a9fff com.apple.applesauce (1.0 - 16.22) <E377E9B9-D02F-36BF-A012-587D55C814F7> /System/Library/PrivateFrameworks/AppleSauce.framework/Versions/A/AppleSauce 0x7fff3fa69000 - 0x7fff3fa6cffb com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <ED587319-ACF9-385F-A8BB-E74E61054FA6> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo 0x7fff3fb06000 - 0x7fff3fb15ff9 com.apple.AssertionServices (1.0 - 223.60.4) <24DF3272-5AE3-3E7B-AECC-5D3E1D1AA303> /System/Library/PrivateFrameworks/AssertionServices.framework/Versions/A/AssertionServices 0x7fff406a9000 - 0x7fff408e6ff7 com.apple.audio.AudioToolboxCore (1.0 - 1104.33) <0DB5EC73-CEEB-3971-B9C8-5263788DEBEC> /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore 0x7fff408e7000 - 0x7fff40a00ff4 com.apple.AuthKit (1.0 - 1) <5B790973-7E89-3D7B-B1C9-56D3A65038CB> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit 0x7fff40bbb000 - 0x7fff40bc4ff3 com.apple.coreservices.BackgroundTaskManagement (1.0 - 104) <D0F2851A-521F-335A-B7C4-B1E39BB42DD7> /System/Library/PrivateFrameworks/BackgroundTaskManagement.framework/Versions/A/BackgroundTaskManagement 0x7fff40bc5000 - 0x7fff40c66ff8 com.apple.backup.framework (1.11.2 - 1298.2.10) <B4C73BEC-CEF3-3C18-AF66-C5BEAAB51AD8> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup 0x7fff40c67000 - 0x7fff40ce8ffd com.apple.BaseBoard (464.1 - 464.1) <3F887960-21C3-3CB2-9DF2-59CA3DB64EB1> /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard 0x7fff40dea000 - 0x7fff40e26fff com.apple.bom (14.0 - 219.2) <06E2ABAD-08EC-3EF5-8C02-38CF3C43C181> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom 0x7fff419ac000 - 0x7fff419fbfff com.apple.ChunkingLibrary (302 - 302) <9FA43C86-7BC1-3CC3-A4CE-74A455CD7709> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary 0x7fff428bb000 - 0x7fff428ccfff com.apple.CommonAuth (4.0 - 2.0) <6B36BE24-8D8B-3EE9-88BA-945B67F3AB6E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x7fff428e0000 - 0x7fff428f7fff com.apple.commonutilities (8.0 - 900) <7FADB6A2-AC75-329A-B4F8-D3A3350B02E9> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities 0x7fff43415000 - 0x7fff43434ff0 com.apple.analyticsd (1.0 - 1) <74ED98BB-5B98-35A9-B6A4-02662EACE8BB> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics 0x7fff4398b000 - 0x7fff4399bff3 com.apple.CoreEmoji (1.0 - 107) <544182E2-893F-3975-AA70-26ADC637B3F1> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji 0x7fff43fef000 - 0x7fff44059ff0 com.apple.CoreNLP (1.0 - 213) <287973D6-1807-3A81-8F57-7BB39209F6C0> /System/Library/PrivateFrameworks/CoreNLP.framework/Versions/A/CoreNLP 0x7fff444cb000 - 0x7fff444d3ff0 com.apple.CorePhoneNumbers (1.0 - 1) <7DC06F8E-A897-38EE-B6E3-721C034F6067> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/Versions/A/CorePhoneNumbers 0x7fff44c20000 - 0x7fff44c43ff7 com.apple.CoreSVG (1.0 - 129) <7254CEB9-8A9C-3E02-A76D-CF858A5D87D5> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG 0x7fff44c44000 - 0x7fff44c77ff7 com.apple.CoreServicesInternal (446.6 - 446.6) <0CCCC36C-E33F-3DF8-B5E8-E1437F242933> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal 0x7fff44c78000 - 0x7fff44ca6ff7 com.apple.CSStore (1069.11 - 1069.11) <26602CC8-0080-3E85-A588-79CEF78D21E5> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore 0x7fff451b4000 - 0x7fff4523bfff com.apple.CoreSymbolication (11.0 - 64509.98.1) <A44F2BDD-D8BA-36B7-97B3-CF4C77C2EA71> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x7fff452d3000 - 0x7fff453ffff4 com.apple.coreui (2.1 - 608.3) <F909B4FA-2D2D-3142-B539-C0CF4A77D07A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x7fff45400000 - 0x7fff4559bff6 com.apple.CoreUtils (6.1 - 610.19) <C1BEC3C0-C2D7-3333-A89C-7C0216DFFFA6> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils 0x7fff456d0000 - 0x7fff456e3ff1 com.apple.CrashReporterSupport (10.13 - 15011.2) <1BFBE272-C431-31BD-9E4F-3F31F680A247> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport 0x7fff4594d000 - 0x7fff4595fffc com.apple.framework.DFRFoundation (1.0 - 252) <C6C87C6D-7FBC-3501-8614-2050FDA0BBC3> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation 0x7fff45960000 - 0x7fff45965fff com.apple.DSExternalDisplay (3.1 - 380) <D8858746-3C00-3718-BC01-F511FA379A06> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay 0x7fff459ce000 - 0x7fff45a49ff8 com.apple.datadetectorscore (8.0 - 659) <4815229E-A03D-3F73-AAD7-D87789DD23EC> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0x7fff45a95000 - 0x7fff45ad3ff0 com.apple.DebugSymbols (194 - 194) <C0388FF0-F6A7-35C8-A274-D8B6AE52241D> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0x7fff45ad4000 - 0x7fff45c31ffe com.apple.desktopservices (1.14.3 - 1281.3.2) <C476CE78-AECF-3D4E-BBF4-EB1A5F57B7AC> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x7fff47473000 - 0x7fff4788eff9 com.apple.vision.FaceCore (4.3.0 - 4.3.0) <0255512B-C869-3DE7-9240-6506D5CC8284> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore 0x7fff47ef2000 - 0x7fff48029ffc libFontParser.dylib (277.2.1.2) <24CC0EED-DC94-3803-AA19-52A329DAFBF5> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib 0x7fff4802a000 - 0x7fff4805efff libTrueTypeScaler.dylib (277.2.1.2) <9FD7CA8F-ED51-3B33-924C-26577FECC147> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib 0x7fff480c3000 - 0x7fff480d3ff6 libhvf.dylib (1.0 - $[CURRENT_PROJECT_VERSION]) <4BD1C9D8-DF67-3CE6-B801-6785C218986E> /System/Library/PrivateFrameworks/FontServices.framework/libhvf.dylib 0x7fff4b598000 - 0x7fff4b599fff libmetal_timestamp.dylib (902.11.1) <9FD477BF-E034-3D0D-970E-FD8BF83D97F4> /System/Library/PrivateFrameworks/GPUCompiler.framework/Versions/3902/Libraries/libmetal_timestamp.dylib 0x7fff4cc34000 - 0x7fff4cc3fff7 libGPUSupportMercury.dylib (17.10.22) <0ACD75CE-10B0-3759-B29D-4087BF2B7386> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib 0x7fff4cc40000 - 0x7fff4cc46fff com.apple.GPUWrangler (4.7.2 - 4.7.2) <BF17B917-2B63-37C5-9030-B14F282723B2> /System/Library/PrivateFrameworks/GPUWrangler.framework/Versions/A/GPUWrangler 0x7fff4cf64000 - 0x7fff4cf8affb com.apple.GenerationalStorage (2.0 - 313) <420F07C2-AB4D-3585-BA3E-380739320932> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage 0x7fff4e0ae000 - 0x7fff4e0bcffb com.apple.GraphVisualizer (1.0 - 100.1) <94660F47-4A85-39D0-BA2B-B387D02477D9> /System/Library/PrivateFrameworks/GraphVisualizer.framework/Versions/A/GraphVisualizer 0x7fff4e24f000 - 0x7fff4e30cff4 com.apple.Heimdal (4.0 - 2.0) <C38A9368-4FAB-30DB-AFFC-9F0665DF2D9C> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fff5044d000 - 0x7fff50455ffd com.apple.IOAccelerator (438.3.1 - 438.3.1) <2E051DEF-89A9-36FD-ABF7-62795A7E7A11> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator 0x7fff50458000 - 0x7fff5046eff7 com.apple.IOPresentment (1.0 - 37) <4584C47E-5A31-372E-91DF-201141E3E41E> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment 0x7fff507f8000 - 0x7fff50843ff4 com.apple.IconServices (438.3 - 438.3) <D52BC60C-BA8C-3759-AA70-9F1B4325C85E> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices 0x7fff50a01000 - 0x7fff50a07ffc com.apple.InternationalSupport (1.0 - 45) <098000C3-AB40-3A6A-AE0B-6FC1B10A08AB> /System/Library/PrivateFrameworks/InternationalSupport.framework/Versions/A/InternationalSupport 0x7fff50c48000 - 0x7fff50c68ff6 com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <9A1C0E52-1671-3687-9F61-B6F821440273> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle 0x7fff50dc0000 - 0x7fff50e8eff5 com.apple.LanguageModeling (1.0 - 215.1) <B47A62F3-7F45-3A84-A856-C674D4613261> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling 0x7fff50e8f000 - 0x7fff50ed7ff7 com.apple.Lexicon-framework (1.0 - 72) <CD6D3F05-0647-348D-AED0-9566F968A954> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon 0x7fff50ede000 - 0x7fff50ee2ff2 com.apple.LinguisticData (1.0 - 353.6.1) <91C3132C-EB52-32D6-9009-DE4B207ACE72> /System/Library/PrivateFrameworks/LinguisticData.framework/Versions/A/LinguisticData 0x7fff5223d000 - 0x7fff52289fff com.apple.spotlight.metadata.utilities (1.0 - 2075.7) <F7FA0F68-7E46-3461-9DA6-C55FBB85C799> /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities 0x7fff5228a000 - 0x7fff52358ffd com.apple.gpusw.MetalTools (1.0 - 1) <9E8CB894-AD09-3264-B013-CBCF31105286> /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools 0x7fff52588000 - 0x7fff525a6ff7 com.apple.MobileKeyBag (2.0 - 1.0) <F2EDE53D-AE96-356E-B8D2-455FF24D3341> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag 0x7fff5280d000 - 0x7fff5283dfff com.apple.MultitouchSupport.framework (3430.1 - 3430.1) <969DA9DA-B08A-3D53-960C-024AEA3E0AB2> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fff52d3d000 - 0x7fff52d47fff com.apple.NetAuth (6.2 - 6.2) <A400CD55-B3EA-371A-8BAB-FDDA87660AE4> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fff53738000 - 0x7fff53784ff7 com.apple.OTSVG (1.0 - 643.1.2.3) <7F19E0AF-9E41-32DE-A19B-37D1C131B230> /System/Library/PrivateFrameworks/OTSVG.framework/Versions/A/OTSVG 0x7fff5491a000 - 0x7fff54925ffe com.apple.PerformanceAnalysis (1.243.1 - 243.1) <D33C31A5-AE17-3455-B33A-62EFBF5DF5E7> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x7fff54926000 - 0x7fff5494effb com.apple.persistentconnection (1.0 - 1.0) <7474CCC1-A27A-38FC-B9D6-BAB08AD736DE> /System/Library/PrivateFrameworks/PersistentConnection.framework/Versions/A/PersistentConnection 0x7fff572ac000 - 0x7fff572c5fff com.apple.ProtocolBuffer (1 - 274.20.7.15.1) <3322B8EE-991A-30C2-BCA1-B81E7DDE7B6B> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer 0x7fff576ce000 - 0x7fff576f7ff9 com.apple.RemoteViewServices (2.0 - 148) <34347997-F06E-3000-B336-093A2B055E31> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x7fff5785d000 - 0x7fff57898ff4 com.apple.RunningBoardServices (1.0 - 223.60.4) <111A73BB-C1CD-35B8-AEFD-98CA52B1514F> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices 0x7fff591e3000 - 0x7fff591e6ff9 com.apple.SecCodeWrapper (4.0 - 448.60.2) <C6EBD591-8132-31FB-991A-368BA9B7444D> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper 0x7fff59359000 - 0x7fff5947dff4 com.apple.Sharing (1506.6 - 1506.6) <4FA735A0-4BDB-384C-B04D-7C2EB3DEDCFB> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing 0x7fff5a495000 - 0x7fff5a78dffa com.apple.SkyLight (1.600.0 - 450.1) <9B2718F3-27FC-319C-98DD-881FD7C742AB> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight 0x7fff5afd5000 - 0x7fff5afe3fff com.apple.SpeechRecognitionCore (6.0.91 - 6.0.91) <10EBEF24-6C75-3E91-B99B-DC1BCD498D8A> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore 0x7fff5b810000 - 0x7fff5b819ff7 com.apple.SymptomDiagnosticReporter (1.0 - 1238.60.1) <921F5137-CD53-35A9-92EA-1A3C412E4C51> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/Versions/A/SymptomDiagnosticReporter 0x7fff5bacf000 - 0x7fff5badfff3 com.apple.TCC (1.0 - 1) <A8308EDB-9AF7-3B6B-AAC3-143F91F58F1D> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fff5bfd4000 - 0x7fff5c09bff4 com.apple.TextureIO (3.10.9 - 3.10.9) <CFA1BB98-DECC-30CB-B923-EFF42B904226> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO 0x7fff5c218000 - 0x7fff5c219fff com.apple.TrustEvaluationAgent (2.0 - 33) <FB6537B0-DA74-3FB7-B364-60828A9CF7E9> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0x7fff5cef2000 - 0x7fff5d14cff2 com.apple.UIFoundation (1.0 - 660) <A48A9528-88BA-3883-9FD9-3150568D7BDA> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation 0x7fff5dd40000 - 0x7fff5dd60fff com.apple.UserManagement (1.0 - 1) <6B41CDA7-B382-36D9-8435-F355DE42C596> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement 0x7fff5eb16000 - 0x7fff5ec01ffe com.apple.ViewBridge (464.1 - 464.1) <AAFB0B7B-8A94-3664-8FEA-A616CD8BFDDD> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge 0x7fff5eda7000 - 0x7fff5eda8fff com.apple.WatchdogClient.framework (1.0 - 67.60.1) <D998CF4B-D757-3B33-A498-5C4259CE882B> /System/Library/PrivateFrameworks/WatchdogClient.framework/Versions/A/WatchdogClient 0x7fff5f985000 - 0x7fff5f988ffa com.apple.dt.XCTTargetBootstrap (1.0 - 15700) <09FE38EC-8B8D-385B-BBF9-48F1133A8E50> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap 0x7fff5fa01000 - 0x7fff5fa0fff5 com.apple.audio.caulk (1.0 - 32.3) <E436DBA4-321E-3C6B-80F3-AE06E44D05C8> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk 0x7fff5fd50000 - 0x7fff5fd52ff3 com.apple.loginsupport (1.0 - 1) <F2EC9213-901A-3657-A36A-DFD80BD8ABBC> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport 0x7fff5fd53000 - 0x7fff5fd66ffd com.apple.login (3.0 - 3.0) <9892EED5-B5C4-3E2F-B89B-7CB0ACECA8B1> /System/Library/PrivateFrameworks/login.framework/Versions/A/login 0x7fff60076000 - 0x7fff600acffa libAudioToolboxUtility.dylib (1104.33) <5426E64E-18E2-33E0-A9A8-BD8D449BA463> /usr/lib/libAudioToolboxUtility.dylib 0x7fff600b3000 - 0x7fff600e8ff7 libCRFSuite.dylib (48) <31D98527-9972-3A4B-9868-C9394FAF742E> /usr/lib/libCRFSuite.dylib 0x7fff600eb000 - 0x7fff600f5ff3 libChineseTokenizer.dylib (34) <9E2B02B0-32A5-3245-AC50-F6BEEC34FCEC> /usr/lib/libChineseTokenizer.dylib 0x7fff60182000 - 0x7fff60184ff7 libDiagnosticMessagesClient.dylib (112) <45E85899-039F-3B99-8789-F497DD9916C2> /usr/lib/libDiagnosticMessagesClient.dylib 0x7fff601c9000 - 0x7fff60380ff3 libFosl_dynamic.dylib (100.4) <84A5F946-01EE-3740-BD2F-4C2A6B1FE82B> /usr/lib/libFosl_dynamic.dylib 0x7fff603a7000 - 0x7fff603adff3 libIOReport.dylib (54) <F60AF538-9EE4-3E10-A289-A015257841B6> /usr/lib/libIOReport.dylib 0x7fff6048d000 - 0x7fff60494fff libMatch.1.dylib (36) <861F4202-5A25-3CA3-98AE-024F91EA95F5> /usr/lib/libMatch.1.dylib 0x7fff604c4000 - 0x7fff604e3fff libMobileGestalt.dylib (826.80.1) <107E3D8D-CCCD-32F4-B858-3F355126F733> /usr/lib/libMobileGestalt.dylib 0x7fff6064a000 - 0x7fff6064bff3 libSystem.B.dylib (1281) <A2C26908-8802-3CA7-8B74-ED4A74AA152C> /usr/lib/libSystem.B.dylib 0x7fff606da000 - 0x7fff606dbfff libThaiTokenizer.dylib (3) <9E5B4E50-E982-387C-AA2F-BB43867322ED> /usr/lib/libThaiTokenizer.dylib 0x7fff606f3000 - 0x7fff60709fff libapple_nghttp2.dylib (1.39.2) <C79E1B79-0BBE-311F-A177-6879D5C4D991> /usr/lib/libapple_nghttp2.dylib 0x7fff6073e000 - 0x7fff607b0ff7 libarchive.2.dylib (72.40.2) <1AE0592D-8451-30D1-AEE8-3F39F46D9DD4> /usr/lib/libarchive.2.dylib 0x7fff607b1000 - 0x7fff60847fc5 libate.dylib (2.0.9) <DE07BAA8-3ABB-317B-BF53-E7B867069B51> /usr/lib/libate.dylib 0x7fff6084b000 - 0x7fff6084bff3 libauto.dylib (187) <71A48A59-FE0E-3D86-A219-B79DAF7CF9DD> /usr/lib/libauto.dylib 0x7fff60912000 - 0x7fff60922ff3 libbsm.0.dylib (60) <5EBEA671-D25B-3425-AC2B-70C2760B8B94> /usr/lib/libbsm.0.dylib 0x7fff60923000 - 0x7fff6092ffff libbz2.1.0.dylib (44) <FA7CE29A-2FE3-3107-8693-5D33D5B7E11F> /usr/lib/libbz2.1.0.dylib 0x7fff60930000 - 0x7fff60983ff7 libc++.1.dylib (800.7) <1D0CB627-8A78-329F-A679-1B5248FF4C59> /usr/lib/libc++.1.dylib 0x7fff60984000 - 0x7fff60998fff libc++abi.dylib (800.7) <7AF668FB-901D-3F45-BA0D-710A235A8D1F> /usr/lib/libc++abi.dylib 0x7fff60999000 - 0x7fff60999ffb libcharset.1.dylib (59) <56F66234-104F-3494-B336-598800CF3F71> /usr/lib/libcharset.1.dylib 0x7fff6099a000 - 0x7fff609abffb libcmph.dylib (8) <9B9AB2BA-75FB-3B70-AAE4-E32B06CF9D69> /usr/lib/libcmph.dylib 0x7fff609ac000 - 0x7fff609c3fe7 libcompression.dylib (87) <A252D9B2-0D88-3345-94DC-E5D7C8245985> /usr/lib/libcompression.dylib 0x7fff60c93000 - 0x7fff60ca9ff7 libcoretls.dylib (167) <6D32CE15-591C-39AD-9A3E-0C2FFC03C3C1> /usr/lib/libcoretls.dylib 0x7fff60caa000 - 0x7fff60cabfff libcoretls_cfhelpers.dylib (167) <3CE60FA9-98FC-3EE0-B398-177F3CAA850D> /usr/lib/libcoretls_cfhelpers.dylib 0x7fff60e4e000 - 0x7fff60f48fff libcrypto.35.dylib (47.11.1) <0CE4FEA8-08AE-31AC-99B8-8FF9B4947DD7> /usr/lib/libcrypto.35.dylib 0x7fff61269000 - 0x7fff612c8fff libcups.2.dylib (483.2) <440F82E8-646B-337D-A60E-976FF2C901ED> /usr/lib/libcups.2.dylib 0x7fff613d4000 - 0x7fff613d4fff libenergytrace.dylib (21) <8E5C9BB2-14F4-37DF-AAE7-8130EBF466A3> /usr/lib/libenergytrace.dylib 0x7fff613d5000 - 0x7fff613eeff7 libexpat.1.dylib (19.60.2) <641F502C-FF8F-3C15-A262-F92F94D7C7E3> /usr/lib/libexpat.1.dylib 0x7fff613fc000 - 0x7fff613fefff libfakelink.dylib (149) <7296A5B3-EE44-34E6-810A-2A12C2D3EF68> /usr/lib/libfakelink.dylib 0x7fff6140d000 - 0x7fff61412fff libgermantok.dylib (24) <7B3FFFFB-5E34-3940-8E0A-B64A2DE42E68> /usr/lib/libgermantok.dylib 0x7fff61413000 - 0x7fff6141cff7 libheimdal-asn1.dylib (564.60.2) <C37C4E10-F1D3-3B62-BDDF-7DBC611ACEC6> /usr/lib/libheimdal-asn1.dylib 0x7fff6141d000 - 0x7fff6150dff7 libiconv.2.dylib (59) <30414773-5E42-3976-B7C3-9BB8883792EE> /usr/lib/libiconv.2.dylib 0x7fff6150e000 - 0x7fff61766ff7 libicucore.A.dylib (64252.0.1) <0F9294A7-6EC0-3279-BF92-3233C89DFA0A> /usr/lib/libicucore.A.dylib 0x7fff61780000 - 0x7fff61781fff liblangid.dylib (133) <EDF945D6-A37D-3DEB-B956-B4745269603D> /usr/lib/liblangid.dylib 0x7fff61782000 - 0x7fff6179aff3 liblzma.5.dylib (16) <F75FB525-C702-3A7E-9239-28D57E677DD5> /usr/lib/liblzma.5.dylib 0x7fff617b2000 - 0x7fff61859fff libmecab.dylib (883.1.1) <A2C923A6-D955-3FF1-82AE-7E54947F9566> /usr/lib/libmecab.dylib 0x7fff6185a000 - 0x7fff61abcfe1 libmecabra.dylib (883.1.1) <971A30D4-1C27-3DD1-AACF-8337AE059F70> /usr/lib/libmecabra.dylib 0x7fff61e2c000 - 0x7fff61e5bff7 libncurses.5.4.dylib (57) <8882C63D-A0EC-3B10-8DD9-FD6419FB7C80> /usr/lib/libncurses.5.4.dylib 0x7fff61f8a000 - 0x7fff62400ff7 libnetwork.dylib (1880.60.5) <8B4092C3-9F1C-34C3-A73D-A2228C345831> /usr/lib/libnetwork.dylib 0x7fff6249f000 - 0x7fff624d0fc6 libobjc.A.dylib (781.2) <7B72F50A-5381-36D7-A616-65D3EA9748A5> /usr/lib/libobjc.A.dylib 0x7fff624e3000 - 0x7fff624e7fff libpam.2.dylib (25) <55302451-C2B2-3DB4-9092-B84E236104DA> /usr/lib/libpam.2.dylib 0x7fff624ea000 - 0x7fff62520ff7 libpcap.A.dylib (89.60.2) <FD167BF3-6984-36E1-9D93-E8B98E3E64A1> /usr/lib/libpcap.A.dylib 0x7fff625a2000 - 0x7fff625baff7 libresolv.9.dylib (67.40.1) <F363FB44-7C6D-3BC6-A897-639C74F9C97B> /usr/lib/libresolv.9.dylib 0x7fff625bc000 - 0x7fff62600fff libsandbox.1.dylib (1217.80.1) <87099525-DB29-3530-87A6-BD484B56E97C> /usr/lib/libsandbox.1.dylib 0x7fff62616000 - 0x7fff62803ff7 libsqlite3.dylib (308.4) <448E300F-0157-3AEA-B199-0DFA914B1547> /usr/lib/libsqlite3.dylib 0x7fff62927000 - 0x7fff62971ff7 libstdc++.6.dylib (104.1) <D90B6BC3-9DCE-3559-83DF-F51D2D699697> /usr/lib/libstdc++.6.dylib 0x7fff62a55000 - 0x7fff62a58ffb libutil.dylib (57) <6CB26E6D-AD27-3FA8-8A30-4AFC3A2AE3F9> /usr/lib/libutil.dylib 0x7fff62a59000 - 0x7fff62a66fff libxar.1.dylib (420) <317EA455-78EE-35A4-B63F-D85993B8697C> /usr/lib/libxar.1.dylib 0x7fff62a6c000 - 0x7fff62b4eff7 libxml2.2.dylib (32.14) <4F4EB304-2AA5-3E5F-AB24-F645E0D16EFC> /usr/lib/libxml2.2.dylib 0x7fff62b52000 - 0x7fff62b7afff libxslt.1.dylib (16.7) <E9BBE609-BA57-368D-95D7-ACA3A8C1AE8B> /usr/lib/libxslt.1.dylib 0x7fff62b7b000 - 0x7fff62b8dffb libz.1.dylib (76) <52250917-039C-3B46-8011-497FEACF3550> /usr/lib/libz.1.dylib 0x7fff635f1000 - 0x7fff635f6ff3 libcache.dylib (83) <11C19883-6F99-390D-AF2A-A85A99DDFC48> /usr/lib/system/libcache.dylib 0x7fff635f7000 - 0x7fff63602fff libcommonCrypto.dylib (60165) <FEE99884-61F0-3332-852B-B0BB8EFF2288> /usr/lib/system/libcommonCrypto.dylib 0x7fff63603000 - 0x7fff6360afff libcompiler_rt.dylib (101.2) <D7367E6D-A27D-3209-A3DB-A6F44582E502> /usr/lib/system/libcompiler_rt.dylib 0x7fff6360b000 - 0x7fff63614fff libcopyfile.dylib (166.40.1) <91670D15-CB30-3277-8AA9-9A299CEAAE27> /usr/lib/system/libcopyfile.dylib 0x7fff63615000 - 0x7fff636acfdb libcorecrypto.dylib (866.80.2) <3B110D82-B403-31E8-8109-8BBC79C928CE> /usr/lib/system/libcorecrypto.dylib 0x7fff637c3000 - 0x7fff63804ff0 libdispatch.dylib (1173.60.1) <5EF42E98-AD0D-3FAE-ABD4-46D791B8343F> /usr/lib/system/libdispatch.dylib 0x7fff63805000 - 0x7fff6383aff7 libdyld.dylib (733.8) <8B0DFE8A-42CF-32C8-B121-83C22BF25F69> /usr/lib/system/libdyld.dylib 0x7fff6383b000 - 0x7fff6383bffb libkeymgr.dylib (30) <7DADC026-70A8-390F-95AF-F3F345760F24> /usr/lib/system/libkeymgr.dylib 0x7fff6383c000 - 0x7fff63848ff7 libkxld.dylib (6153.81.5) <7572CC82-E7E1-3C38-825F-9B34E2EADAD0> /usr/lib/system/libkxld.dylib 0x7fff63849000 - 0x7fff63849ff7 liblaunch.dylib (1738.80.8) <C4EA8803-E506-3514-9839-9BBECC819953> /usr/lib/system/liblaunch.dylib 0x7fff6384a000 - 0x7fff6384fff7 libmacho.dylib (949.0.1) <395ABE7C-D2B1-343D-A451-9CEA98FDC12E> /usr/lib/system/libmacho.dylib 0x7fff63850000 - 0x7fff63852ff7 libquarantine.dylib (110.40.3) <560961FC-1FEF-3F07-8406-17A36558870E> /usr/lib/system/libquarantine.dylib 0x7fff63853000 - 0x7fff63854ff7 libremovefile.dylib (48) <E99833DE-CB1D-31AB-A948-2739AF503599> /usr/lib/system/libremovefile.dylib 0x7fff63855000 - 0x7fff6386cfff libsystem_asl.dylib (377.60.2) <21A259BC-F892-34EB-9A67-11232AD8913A> /usr/lib/system/libsystem_asl.dylib 0x7fff6386d000 - 0x7fff6386dfff libsystem_blocks.dylib (74) <8B23F806-8153-3163-B5D8-2C3327E211D8> /usr/lib/system/libsystem_blocks.dylib 0x7fff6386e000 - 0x7fff638f5ff7 libsystem_c.dylib (1353.60.8) <99202CC3-2E27-3680-A8FF-5C516C485E90> /usr/lib/system/libsystem_c.dylib 0x7fff638f6000 - 0x7fff638f9ffb libsystem_configuration.dylib (1061.80.3) <8A149700-51AA-3205-A9D4-FF2A7BFC5412> /usr/lib/system/libsystem_configuration.dylib 0x7fff638fa000 - 0x7fff638fdff7 libsystem_coreservices.dylib (114) <CCC076FA-310D-3FC9-950D-41E0F8DDA5D2> /usr/lib/system/libsystem_coreservices.dylib 0x7fff638fe000 - 0x7fff63906fff libsystem_darwin.dylib (1353.60.8) <31ACD3CC-6DD9-3F2E-B163-9342BE1D0AB0> /usr/lib/system/libsystem_darwin.dylib 0x7fff63907000 - 0x7fff6390effb libsystem_dnssd.dylib (1096.60.2) <BEBB815A-065A-365E-9701-8E05A8CF2040> /usr/lib/system/libsystem_dnssd.dylib 0x7fff6390f000 - 0x7fff63910ffb libsystem_featureflags.dylib (17) <340AD606-7C39-3E6A-BAC3-EA1273FC27A4> /usr/lib/system/libsystem_featureflags.dylib 0x7fff63911000 - 0x7fff6395efff libsystem_info.dylib (538) <B0EBAE05-01AD-3D8E-92CC-5704394FF94A> /usr/lib/system/libsystem_info.dylib 0x7fff6395f000 - 0x7fff6398bff7 libsystem_kernel.dylib (6153.81.5) <23909F45-79C3-34C9-A28F-337915925E5E> /usr/lib/system/libsystem_kernel.dylib 0x7fff6398c000 - 0x7fff639d3fcf libsystem_m.dylib (3178) <7D775039-51B8-356E-82D7-98449065518A> /usr/lib/system/libsystem_m.dylib 0x7fff639d4000 - 0x7fff639fbfff libsystem_malloc.dylib (283.60.1) <00190446-C6A8-3EA6-92D1-850EA85C84CE> /usr/lib/system/libsystem_malloc.dylib 0x7fff639fc000 - 0x7fff63a09ffb libsystem_networkextension.dylib (1095.60.2) <1E7A59D0-BBCD-3CB0-8AD1-D442A1A5268E> /usr/lib/system/libsystem_networkextension.dylib 0x7fff63a0a000 - 0x7fff63a13ff3 libsystem_notify.dylib (241) <AB3FAC47-A830-3158-8D99-DBC728CED1D6> /usr/lib/system/libsystem_notify.dylib 0x7fff63a14000 - 0x7fff63a1dfef libsystem_platform.dylib (220) <3DAFCC01-B768-3FFC-AC59-47AAE86BBEA1> /usr/lib/system/libsystem_platform.dylib 0x7fff63a1e000 - 0x7fff63a28fff libsystem_pthread.dylib (416.60.2) <AAF506F4-9455-3CC4-8E0B-6791E3C0993C> /usr/lib/system/libsystem_pthread.dylib 0x7fff63a29000 - 0x7fff63a2dfff libsystem_sandbox.dylib (1217.80.1) <C8F3841A-9364-3414-9E3F-9DE3D5FECF0C> /usr/lib/system/libsystem_sandbox.dylib 0x7fff63a2e000 - 0x7fff63a30fff libsystem_secinit.dylib (62.80.1) <32F36517-9A1C-3D30-85C8-611A2F5E2355> /usr/lib/system/libsystem_secinit.dylib 0x7fff63a31000 - 0x7fff63a38ffb libsystem_symptoms.dylib (1238.60.1) <2EDF9CE8-4091-30A8-B125-0F25E579694A> /usr/lib/system/libsystem_symptoms.dylib 0x7fff63a39000 - 0x7fff63a4fff2 libsystem_trace.dylib (1147.80.3) <AE11B1AC-352A-37F0-BCA9-055609070104> /usr/lib/system/libsystem_trace.dylib 0x7fff63a51000 - 0x7fff63a56ffb libunwind.dylib (35.4) <E867ACDE-EADE-3C91-A2A4-0C401788FD47> /usr/lib/system/libunwind.dylib 0x7fff63a57000 - 0x7fff63a8cffe libxpc.dylib (1738.80.8) <51E3E807-9133-3605-BB5F-D59ED6404ABF> /usr/lib/system/libxpc.dylib External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 2043279 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=709.6M resident=0K(0%) swapped_out_or_unallocated=709.6M(100%) Writable regions: Total=679.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=679.1M(100%) VIRTUAL REGION REGION TYPE SIZE COUNT (non-coalesced) =========== ======= ======= Accelerate framework 384K 3 Activity Tracing 256K 1 CG backing stores 1328K 4 CG image 12K 2 CoreAnimation 36K 7 CoreGraphics 8K 1 CoreImage 32K 4 CoreUI image data 472K 7 Foundation 4K 1 Kernel Alloc Once 8K 1 MALLOC 221.1M 60 MALLOC guard page 32K 6 MALLOC_LARGE (reserved) 53.9M 3 reserved VM address space (unallocated) MALLOC_NANO (reserved) 384.0M 1 reserved VM address space (unallocated) STACK GUARD 56.0M 12 Stack 13.6M 12 VM_ALLOCATE 112K 17 __DATA 41.8M 297 __DATA_CONST 20K 1 __FONT_DATA 4K 1 __GLSLBUILTINS 5176K 1 __LINKEDIT 379.6M 11 __OBJC_RO 32.0M 1 __OBJC_RW 1780K 2 __TEXT 330.0M 287 __UNICODE 564K 1 mapped file 57.5M 19 shared memory 648K 16 =========== ======= ======= TOTAL 1.5G 779 TOTAL, minus reserved VM space 1.1G 779 Model: MacBookPro11,3, BootROM 158.0.0.0.0, 4 processors, Quad-Core Intel Core i7, 2,3 GHz, 16 GB, SMC 2.19f12 Graphics: kHW_IntelIrisProItem, Intel Iris Pro, spdisplays_builtin Graphics: kHW_NVidiaGeForceGTX750MItem, NVIDIA GeForce GT 750M, spdisplays_pcie_device, 2 GB Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020 Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54343147533641465238412D50422020 AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x134), Broadcom BCM43xx 1.0 (7.77.106.3 AirPortDriverBrcmNIC-1440.1) Bluetooth: Version 7.0.3f5, 3 services, 27 devices, 1 incoming serial ports Network Service: Wi-Fi, AirPort, en0 Serial ATA Device: APPLE SSD SM0512F, 500,28 GB USB Device: USB 3.0 Bus USB Device: Apple Internal Keyboard / Trackpad USB Device: BRCM20702 Hub USB Device: Bluetooth USB Host Controller USB Device: Keyboard Hub USB Device: USB Receiver USB Device: Apple Keyboard Thunderbolt Bus: MacBook Pro, Apple Inc., 17.1
I recently can across a issue where I heavy need to import a obj file with textures already applied. For context I have a model that had multiple texture sheets and UV'd pieces that have existing textures I need to edit. Problem is that when importing any type of geometry file the program does not apply textures automatically. Ordinarily this wouldn't be a issue as having only one or two texture sheets wouldn't take much time to import the textures manually. Thing is that this project has upwards of 12 separate UV'd pieces, each with around 4 textures. Meaning that I would need to manually apply 48 textures for this one model. If there are any tricks or ways around this problem please reply back, as I will even try external plugins a try for fixing this issue. This is urgent as the window on this project is closing quickly. Thank you for reading and hope to hear back soon.
I recently started to get back into 3d coat, and decided to go back into my 4.5 version, but after fooling around and having my cat stupidly run across my keyboard after being spooked, I can't seem to paint on the models I'm using anymore? Whenever I go to draw or color on any part of the model, it erases instead of coloring. I've looked through the settings, tried all the keybinds, uninstalled and reinstalled probably about 10 times, restarted my computer about 4 times, unplugged and even restarted my tablet drivers, and nothing. Can someone help out?
Hello I'm sculpting in zbrush, exporting as .obj and then importing to 3D Coat for manual retopololgy. However, when I import the .obj in 3D Coat, what I get is like a soft, inflated version of my object. It works fine when I open it zbrush again. Any ideas? Apologies if this is a dumb question or in the wrong spot, I'm new to 3D Coat and this forum Thanks!
- 16 replies
- zbrush
- retopology
